ac/dc module & heat transfer module
Topics: 4.3
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   5 Replies   Last post: February 11, 2014 7:23am UTC
Stitaprangya Dash
Stitaprangya Dash
February 10, 2014 6:37am UTC
I have designed a double spiral micro heater using ac/dc & heat transfer module.I have used aluminium material & this is giving heat of 1300k at 0.2v supply voltage(DC).But i am unable to determine the power consumption of the heater so that am not able to choose the write material for the model.So would you be kind enough to tell me the procedure to calculate the power consumption of the heater.
Stitaprangya Dash,India
Julien Givernaud
Julien Givernaud
February 10, 2014 11:34am UTC in response to Stitaprangya Dash
Re: ac/dc module & heat transfer module
In wich dimension do tou design your heater? 2d-axy
Do you use Coil domain?
Tell us more
Julien
Stitaprangya Dash
Stitaprangya Dash
February 10, 2014 12:02pm UTC in response to Julien Givernaud
hello sir,
I have designed the model in 3D, using different rectangle and then making union of those all to form the complete model.sir my query is that, i have to determine the power consume by the model, so that i can make changes accordingly for better result. I have not taken thermal expansion physics for the model.so you kindly direct me how i calculate the power consumption so able to plot graph between power consumption vs. temperature that the heater is heating.
thanks
Stitaprangya Dash.
Julien Givernaud
Julien Givernaud
February 10, 2014 12:16pm UTC in response to Stitaprangya Dash
Ok in 3D,
Your study is a frequency domain (AC excitation)? Stationnary(DC)?
do you use a single turn coil domain?
How do you excite the heaters?
Stitaprangya Dash
Stitaprangya Dash
February 11, 2014 6:47am UTC in response to Julien Givernaud
Sir my study is based on stationary(DC) & I have used single turn coil domain.I supplied 0.2v at one of the terminal of the heater and made other terminal ground in ac/dc module .Then in the heat transfer module i added the heat source and temperature physics to the model.The model is running successfully but how will i determine how much power does heater consume.
Julien Givernaud
Julien Givernaud
February 11, 2014 7:23am UTC in response to Stitaprangya Dash
If you use a single turn coil, you can measure the power with a global evaluation
derived values-> global evaluation -> mf -> coil parameters -> coil power
You can check this value with a boundary integration of your heaters
The transfert is done by radiation, you can measure the radiative heat flux over all the boundaries,
Coil power and the sum of radiative heat fluxes must be very close
Julien
Rules and guidelines
