3D simulation: Extract 2D integrated solution values along a path
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   6 Replies   Last post: June 28, 2011 8:04pm UTC
Arian Kirsch
Arian Kirsch
January 4, 2011 8:36pm UTC
I have solved a 3D problem with the RF module, electromagnetic waves (emw), which gives me a nice 3-dimensional electric field distribution.
Now I have a problem with the evaluation, maybe someone of you can help me.
The geometry is sth. extruded from a 2D geometry. In 2D there is a rectangle (R), centered to x,y=0, which in 3D into the z dimension becomes extruded to a long (prolate) rectangular block. It is kind of a waveguide.
What I need: The power flow into z direction (P), integrated in a plane, which is the rectangle (R) over the z coordinate.
I now already tried, defining me a Results-> Datasets->CutLine 3D.
Is this the right approach? Is it possible to define there a 2D integration which I can extract as a scalar along the z (1D) extension?
I have also already included a "line" object in my geometry, central (x,y=0), as I hoped, maybe, I could at least get scalar values along this line. But in principle I want to do this aforementioned 2D integration before going along the line.
To be honest, at this point I am now a bit at a loss.
Has anyone of you already done this?
I guess, if it is then in this discussion forum as an answer, maybe it could be also a good help for others ;-)
Best regards!
Arian
Ivar Kjelberg
Ivar Kjelberg
January 5, 2011 6:46am UTC in response to Arian Kirsch
Re: 3D simulation: Extract 2D integrated solution values along a path
in 4.1 you can define a cut plane ("artificial" interpolated boundary in the results data set) and then integrate over this plane. Often I cut my geometry to have an interiour boundary that I can select and define some probe or integration operator thereon and use them in the postprocessing
Cheng Chen
Cheng Chen
June 6, 2011 8:30pm UTC in response to Ivar Kjelberg
Hi Ivar,
I'm using Comsol 4.1 to solve liquid flow and heat transfer problem in channels. What I need is to evaluate integration or average value on a cross-section plane. I know I can define a "cut plane" to do this. But is there any method to define the boundary of the plane, since on the same plane I've other structures which are not of interest.
I wonder if "parameterized surface" would be a possible solution. But I could not find sufficient instruction information concerning that topic in the help file.
Thank you.
Cheng
Ivar Kjelberg
Ivar Kjelberg
June 7, 2011 10:38am UTC in response to Cheng Chen
but cannt you cut then your geoemtry such that you have a boundary you can integrate over ?
Cheng Chen
Cheng Chen
June 7, 2011 5:35pm UTC in response to Ivar Kjelberg
I used to cut my geometry in the drawing step and it works. But is it possible to cut it in the postprocessing step? I don't want to reconstruct the model and solve it again and again for postprocessing purpose.
Thank you.
Cheng
Jeff Hiller
Jeff Hiller
COMSOL Employee
USA
Moderator
June 7, 2011 5:46pm UTC in response to Cheng Chen
You could use a cut plane dataset combined with an integration expression that involves a boolean. Something like T*(dom==1) if you want to integrate T and only integrate on the intersection of your cutplane with domain 1.
Angela Yurie
Angela Yurie
June 28, 2011 8:04pm UTC in response to Cheng Chen
Hello, Cheng.
Have you managed to solve this issue? Could you help me, please? I am in the same situation now.
Thank you
Rules and guidelines
