contact with friction
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   2 Replies   Last post: March 24, 2012 5:52pm UTC
Andrew Schmalzer
Andrew Schmalzer
December 15, 2010 8:25pm UTC
So I'm trying to model a block sliding on a flat surface with friction.
My setup includes:
a) a block that is .1m tall, 2m wide and 10m long
b) a block that is .1m tall, 1m wide and .75m long
Configuration:
block b is sitting on top of and at the edge of block a.
(there is a .01m distance between the surfaces so that the two blocks do not form a union)
Constraints (structural mechanics):
I applied a fixed constraint to block a
I have the two blocks set up as a contact pair, and have a contact pair constraint set with dynamic friction
I have a boundary load applied to the side of block b that is intended to push it along the length of block a
I have a boundary load applied to the top of block b to assert a gravitational force
I have the materials set as 1018 steel
I have a finer mesh on block a
Here are the problems I'm having:
- the displacement of block b doesn't change as the dynamic friction coefficient is increased.
- block b seems to be protruding through the contact surface of block a
Thanks for any tips or suggestions !
andrew
Ivar Kjelberg
Ivar Kjelberg
December 16, 2010 7:18am UTC in response to Andrew Schmalzer
Re: contact with friction
there was a nice documented model in 3.5a, do not know if it's ported to v4 yet but probably you scould find your answers therein
Rhythm Wadhwa
Rhythm Wadhwa
March 24, 2012 5:52pm UTC in response to Ivar Kjelberg
Hi Ivar,
Whats the name of that model? Is it accessible for 4.2a?
Rules and guidelines
