Filter by Topic
Most Popular
All Topics
- List all discussions
format of interpolation function data file
January 20, 2010 2:39am UTC
Hi,teacher,
I have defined an interpolation from the data file D205.txt, which makes a side length of 500 mm square divided by equally spaced 10 mm grid, and then gives the data of each grid nodes, but when I defined in comsol document interpolation function D205 (x, y) starting the calculation, the total prompt interpolation data errors, I am very confused, not knowing where is wrong, and I want to know what is the format of data file ? Another problem is that, if I choose unit system is SI, so when drawing in geometry, the geometric dimensions are all said to m, then if defining a constant or variable with mm unit, is to add [mm] after constants or variables?
Thank you!
B.Fenn
D205.txt data file just as:
% grid
0.0000000000000000e+000 1.0000000000000000e+001 2.0000000000000000e+001 3.0000000000000000e+001 4.0000000000000000e+001 5.0000000000000000e+001 6.0000000000000000e+001 7.0000000000000000e+001 8.0000000000000000e+001 9.0000000000000000e+001 1.0000000000000000e+002 1.1000000000000000e+002 1.2000000000000000e+002 1.3000000000000000e+002 1.4000000000000000e+002 1.5000000000000000e+002 1.6000000000000000e+002 1.7000000000000000e+002 1.8000000000000000e+002 1.9000000000000000e+002 2.0000000000000000e+002 2.1000000000000000e+002 2.2000000000000000e+002 2.3000000000000000e+002 2.4000000000000000e+002 2.5000000000000000e+002 2.6000000000000000e+002 2.7000000000000000e+002 2.8000000000000000e+002 2.9000000000000000e+002 3.0000000000000000e+002 3.1000000000000000e+002 3.2000000000000000e+002 3.3000000000000000e+002 3.4000000000000000e+002 3.5000000000000000e+002 3.6000000000000000e+002 3.7000000000000000e+002 3.8000000000000000e+002 3.9000000000000000e+002 4.0000000000000000e+002 4.1000000000000000e+002 4.2000000000000000e+002 4.3000000000000000e+002 4.4000000000000000e+002 4.5000000000000000e+002 4.6000000000000000e+002 4.7000000000000000e+002 4.8000000000000000e+002 4.9000000000000000e+002
5.0000000000000000e+002
0.0000000000000000e+000 1.0000000000000000e+001 2.0000000000000000e+001 3.0000000000000000e+001 4.0000000000000000e+001 5.0000000000000000e+001 6.0000000000000000e+001 7.0000000000000000e+001 8.0000000000000000e+001 9.0000000000000000e+001 1.0000000000000000e+002 1.1000000000000000e+002 1.2000000000000000e+002 1.3000000000000000e+002 1.4000000000000000e+002 1.5000000000000000e+002 1.6000000000000000e+002 1.7000000000000000e+002 1.8000000000000000e+002 1.9000000000000000e+002 2.0000000000000000e+002 2.1000000000000000e+002 2.2000000000000000e+002 2.3000000000000000e+002 2.4000000000000000e+002 2.5000000000000000e+002 2.6000000000000000e+002 2.7000000000000000e+002 2.8000000000000000e+002 2.9000000000000000e+002 3.0000000000000000e+002 3.1000000000000000e+002 3.2000000000000000e+002 3.3000000000000000e+002 3.4000000000000000e+002 3.5000000000000000e+002 3.6000000000000000e+002 3.7000000000000000e+002 3.8000000000000000e+002 3.9000000000000000e+002 4.0000000000000000e+002 4.1000000000000000e+002 4.2000000000000000e+002 4.3000000000000000e+002 4.4000000000000000e+002 4.5000000000000000e+002 4.6000000000000000e+002 4.7000000000000000e+002 4.8000000000000000e+002 4.9000000000000000e+002 5.0000000000000000e+002
% data
0.598691 0.541112 0.480315 0.427825 0.394205 0.387325 0.410935 0.463975 0.540698 0.631544 0.724569 0.807225 0.868159 0.898748 0.894161 0.853845 0.781405 0.683985 0.571225 0.454126 0.343863 0.25066 0 0 0 0 0 0.326939 0.429158 0.535185 0.632708 0.709554 0.755094 0.761683 0.725952 0.64969 0.540144 0.40955 0.273895 0 0 0 0 0 0 0.322915 0.484935 0.644245 0.780195 0.875345 0.918245
0.575111 0.562705 0.538536 0.509355 0.483145 0.467555 0.468355 0.488375 0.526865 0.579656 0.639785 0.698699 0.747607 0.77883 0.786935 0.769395 0.726865 0.662915 0.583475 0.496055 0.408829 0.329786 0.266061 0 0 0 0.248941 0.306553 0.381671 0.466742 0.552555 0.62901 0.686168 0.715494 0.711161 0.671187 0.598204 0.49964 0.387182 0.275509 0 0 0 0 0 0.309449 0.449135 0.596865 0.733145 0.839785 0.902825
0.478503 0.518431 0.547036 0.563846 0.570856 0.571685 0.570525 0.571075 0.575685 0.584985 0.597771 0.61149 0.622835 0.628516 0.625945 0.613685 0.591685 0.561145 0.524285 0.483855 0.442815 0.403965 0.369811 0.342512 0.323906 0.315528 0.318558 0.333629 0.360548 0.397957 0.443067 0.491585 0.537931 0.575806 0.599056 0.602746 0.584226 0.543981 0.486042 0.417809 0.349228 0.291401 0.254834 0.247606 0.273806 0.332547 0.417785 0.518995 0.622765 0.714825 0.782415
0.35639 0.429329 0.499238 0.559681 0.606611 0.63836 0.655225 0.658835 0.651475 0.635535 0.613215 0.58637 0.556665 0.525729 0.495323 0.467375 0.443825 0.426385 0.416135 0.413145 0.416405 0.423795 0.432409 0.439142 0.441317 0.437334 0.427125 0.412281 0.39582 0.381591 0.373441 0.374323 0.385527 0.406245 0.433567 0.462968 0.489171 0.507252 0.51373 0.507417 0.489813 0.464951 0.438697 0.417615 0.407645 0.412844 0.434489 0.470685 0.516715 0.565795 0.610525
0.283805 0.358431 0.43869 0.516139 0.58397 0.637427 0.673814 0.692229 0.693139 0.677994 0.648912 0.608523 0.560018 0.507125 0.454098 0.405546 0.366041 0.339585 0.328915 0.334945 0.356375 0.389585 0.428961 0.467754 0.499043 0.516953 0.517734 0.500519 0.467595 0.424111 0.377232 0.334917 0.304513 0.291452 0.298298 0.324321 0.365676 0.416163 0.468386 0.515091 0.550417 0.570822 0.575521 0.566364 0.547246 0.52317 0.499206 0.479565 0.466975 0.462475 0.465625
0.313341 0.367491 0.427848 0.487928 0.542571 0.588239 0.622939 0.645869 0.656954 0.656432 0.644633 0.621991 0.589283 0.547972 0.500532 0.450596 0.402804 0.362333 0.334135 0.322055 0.327945 0.351065 0.387895 0.432508 0.477297 0.514282 0.536451 0.53907 0.520633 0.483261 0.432465 0.376282 0.323941 0.28429 0.264299 0.267868 0.295213 0.34287 0.404351 0.471276 0.534773 0.58688 0.621698 0.636115 0.630015 0.605989 0.568668 0.523839 0.477545 0.435375 0.401855
0.438385 0.472435 0.501826 0.523508 0.536676 0.542626 0.544153 0.544622 0.546964 0.552809 0.561996 0.572547 0.58113 0.5839 0.577521 0.560124 0.531975 0.495665 0.455786 0.418115 0.388475 0.371535 0.369795 0.382947 0.407841 0.439031 0.469775 0.493362 0.504441 0.500116 0.480553 0.449002 0.41121 0.374351 0.345693 0.331238 0.334642 0.356555 0.394553 0.443599 0.496954 0.547332 0.588072 0.614126 0.622698 0.613461 0.58838 0.551214 0.506865 0.460685 0.417885
0.595055 0.628465 0.639299 0.626328 0.59253 0.544648 0.491997 0.444798 0.412305 0.401095 0.41384 0.448784 0.500058 0.558742 0.614492 0.657424 0.679877 0.677744 0.651132 0.604217 0.544375 0.480755 0.422605 0.377648 0.350875 0.34384 0.354726 0.378977 0.410419 0.442572 0.469897 0.488744 0.497815 0.498108 0.492395 0.484389 0.477809 0.475533 0.479046 0.488232 0.501542 0.516463 0.53013 0.539953 0.544098 0.541756 0.533153 0.519365 0.502012 0.482937 0.463975
0.702271 0.756028 0.771706 0.74678 0.684961 0.595793 0.493289 0.393796 0.313413 0.265398 0.257998 0.293079 0.365805 0.465402 0.576911 0.683603 0.769643 0.822562 0.83511 0.806211 0.740878 0.649185 0.544425 0.440985 0.352054 0.287831 0.254276 0.252679 0.279983 0.329749 0.393501 0.462199 0.52755 0.582982 0.624178 0.649147 0.657959 0.652236 0.634598 0.608152 0.576131 0.54168 0.50777 0.477147 0.452271 0.435177 0.427259 0.429033 0.439915 0.458164 0.480999
0.713719 0.791171 0.825735 0.81178 0.750668 0.650831 0.526749 0.396939 0.281234 0 0 0 0.242129 0.352084 0.489905 0.636216 0.770439 0.873883 0.932504 0.93887 0.89308 0.802455 0.680205 0.543265 0.409673 0.296024 0 0 0 0 0.294721 0.389938 0.49402 0.595075 0.682765 0.749215 0.789477 0.801604 0.786435 0.747185 0.688955 0.618209 0.542243 0.468643 0.4047 0.356783 0.329709 0.326146 0.346171 0.387091 0.443601
0.646835 0.726616 0.771074 0.772768 0.730153 0.648164 0.537854 0.415024 0.298045 0 0 0 0 0.290205 0.420535 0.568807 0.714873 0.838742 0.92357 0.958096 0.938205 0.867345 0.755845 0.619145 0.475485 0.343185 0 0 0 0 0 0.331128 0.442452 0.558588 0.667045 0.757209 0.821197 0.854286 0.854968 0.824751 0.767783 0.690368 0.600428 0.506905 0.419082 0.345827 0.294759 0.27141 0.278472 0.315276 0.377615
0.569251 0.615735 0.640887 0.639514 0.609822 0.55412 0.47894 0.394447 0.313189 0.248304 0 0 0.250085 0.326285 0.431355 0.552375 0.673545 0.778537 0.852947 0.886497 0.874595 0.818975 0.727385 0.612335 0.489165 0.373745 0.280237 0 0 0 0.263742 0.341472 0.435561 0.53478 0.628491 0.707753 0.766022 0.79941 0.806605 0.78856 0.748085 0.689445 0.618028 0.540057 0.46232 0.391826 0.335338 0.298776 0.286501 0.300613 0.340392
0.551653 0.536305 0.510594 0.476006 0.434802 0.390192 0.34641 0.308574 0.282249 0.272748 0.284235 0.318785 0.375635 0.450815 0.537235 0.625375 0.704538 0.764323 0.796293 0.795421 0.761035 0.697095 0.611775 0.516245 0.423035 0.344125 0.289204 0.264241 0.270803 0.306032 0.36339 0.433921 0.507809 0.575923 0.631083 0.668836 0.687667 0.688666 0.674799 0.649986 0.618212 0.582863 0.546401 0.510402 0.475875 0.443726 0.415188 0.392063 0.376662 0.371461 0.378513
0.618748 0.538118 0.448569 0.360254 0.282569 0 0 0 0 0.249402 0.320265 0.408355 0.506075 0.604575 0.694375 0.766255 0.812273 0.826778 0.807384 0.755565 0.67683 0.580295 0.477725 0.382005 0.305355 0.257565 0.244435 0.26686 0.32062 0.397015 0.484226 0.569202 0.639732 0.686372 0.703847 0.691734 0.654279 0.599427 0.537245 0.478065 0.430673 0.400903 0.390855 0.398859 0.420144 0.448044 0.47546 0.496292 0.506546 0.504925 0.492826
0.731448 0.609694 0.471712 0.334497 0 0 0 0 0 0 0.310205 0.444455 0.585015 0.717585 0.828615 0.906575 0.943242 0.934567 0.881347 0.789381 0.669077 0.534485 0.401775 0.287275 0 0 0 0 0.323784 0.441767 0.567314 0.682184 0.769709 0.81734 0.818555 0.773859 0.690655 0.582019 0.464558 0.355739 0.271104 0 0 0.244077 0.306769 0.389329 0.477221 0.555879 0.613024 0.640487 0.635231
0.81246 0.686679 0.535901 0.379388 0 0 0 0 0 0 0.289035 0.439905 0.600305 0.753335 0.882917 0.975461 1.02125 1.0154 0.958618 0.857209 0.722663 0.570555 0.418905 0.286115 0 0 0 0 0.305095 0.43996 0.587041 0.725252 0.834458 0.898453 0.907429 0.85955 0.761313 0.626627 0.474734 0.327282 0 0 0 0 0 0.304116 0.429863 0.552831 0.654279 0.719375 0.739244
0.798219 0.696437 0.567989 0.429809 0.299708 0 0 0 0 0 0.307555 0.441385 0.586705 0.728428 0.85201 0.944911 0.997731 1.00517 0.966588 0.886214 0.772875 0.639264 0.50073 0.37364 0.273485 0 0 0 0.317597 0.432935 0.566243 0.698451 0.810065 0.884009 0.908244 0.877725 0.795357 0.671739 0.523714 0.371892 0 0 0 0 0 0.257674 0.384943 0.517974 0.636297 0.722114 0.762885
0.682322 0.608888 0.517876 0.421875 0.333949 0.265806 0 0 0.248715 0.308085 0.391815 0.490975 0.595475 0.695238 0.781093 0.845568 0.883387 0.89177 0.87059 0.822365 0.752132 0.667139 0.576342 0.48967 0.417054 0.367284 0.346825 0.358752 0.40198 0.471045 0.556481 0.645874 0.725487 0.782253 0.805833 0.790401 0.73581 0.647913 0.537913 0.420803 0.313115 0 0 0 0 0.298799 0.399139 0.50705 0.605278 0.678177 0.714122
0.52133 0.45922 0.395351 0.339263 0.299527 0.282379 0.290775 0.324015 0.377985 0.445965 0.519855 0.591385 0.653415 0.700815 0.730891 0.743402 0.740153 0.724325 0.69974 0.670202 0.639049 0.60895 0.581935 0.559561 0.543098 0.533632 0.532005 0.538598 0.553002 0.573703 0.597905 0.621602 0.639988 0.648151 0.641988 0.619142 0.579767 0.526912 0.4664 0.406128 0.354889 0.320882 0.310179 0.325452 0.365209 0.423758 0.491906 0.558345 0.611485 0.641411 0.64162
0.399052 0.326939 0.266456 0 0 0 0.286812 0.362024 0.452565 0.546855 0.632855 0.699925 0.740585 0.751575 0.734205 0.69407 0.639884 0.58194 0.530361 0.493468 0.476565 0.481309 0.505732 0.544863 0.591772 0.63882 0.678864 0.706256 0.717372 0.710899 0.687558 0.649768 0.601051 0.545578 0.487747 0.431941 0.382385 0.343029 0.317404 0.308351 0.317641 0.345503 0.390201 0.447758 0.511995 0.574964 0.627794 0.661887 0.670288 0.648991 0.59794
0.373224 0.285055 0 0 0 0 0 0.333414 0.447165 0.565735 0.673425 0.755955 0.802705 0.808425 0.774066 0.706671 0.618182 0.523544 0.438289 0.37609 0.346666 0.354366 0.397659 0.469555 0.558853 0.651974 0.735055 0.795945 0.825775 0.820075 0.779005 0.707125 0.612508 0.505561 0.397713 0.300116 0 0 0 0 0 0.293127 0.38704 0.490011 0.590479 0.676462 0.736819 0.762612 0.748409 0.693327 0.60162
0.440071 0.35322 0.271273 0 0 0 0 0.288047 0.391389 0.508882 0.624675 0.722745 0.789385 0.815522 0.79822 0.741242 0.654508 0.552528 0.452092 0.36959 0.318404 0.306823 0.336804 0.40375 0.497332 0.60317 0.705075 0.787455 0.837585 0.847275 0.813885 0.740415 0.634935 0.509355 0.377783 0.254789 0 0 0 0 0 0 0.326509 0.452245 0.575902 0.682912 0.759929 0.796371 0.785829 0.727158 0.625063
0.539923 0.485921 0.421039 0.355631 0.301032 0.267651 0.263075 0.290567 0.348249 0.429164 0.522246 0.614062 0.691017 0.741701 0.758844 0.740623 0.691036 0.619259 0.538106 0.461859 0.403849 0.374222 0.378249 0.415484 0.479883 0.560834 0.644908 0.717995 0.767505 0.784205 0.763535 0.706075 0.617425 0.507185 0.387629 0.272075 0 0 0 0 0 0 0.277423 0.390334 0.505222 0.608877 0.688772 0.734411 0.738617 0.698621 0.616787
0.599305 0.603269 0.583906 0.545348 0.495206 0.443241 0.399599 0.372962 0.368948 0.38908 0.430522 0.486636 0.548257 0.605429 0.649269 0.673612 0.676096 0.658508 0.626324 0.587546 0.551084 0.524989 0.514891 0.522928 0.54737 0.582965 0.621946 0.655465 0.675205 0.674815 0.651005 0.604055 0.537705 0.458525 0.374915 0.295791 0 0 0 0 0 0 0.301879 0.375165 0.449888 0.518094 0.572147 0.605375 0.612754 0.591593 0.542135
0.580632 0.643388 0.680506 0.688412 0.668231 0.625435 0.568764 0.508617 0.455226 0.416965 0.399078 0.403068 0.426776 0.465193 0.5116 0.559041 0.601595 0.635315 0.658647 0.672269 0.678461 0.680163 0.67999 0.679422 0.678359 0.675143 0.667021 0.650927 0.624375 0.586315 0.537625 0.481215 0.421725 0.364815 0.316195 0.280685 0.261406 0.259326 0.273175 0.299776 0.334675 0.372915 0.409789 0.441432 0.465149 0.479454 0.48389 0.478713 0.464586 0.44238 0.413167
0.506068 0.601301 0.678238 0.727854 0.745329 0.730625 0.688298 0.626555 0.555791 0.486876 0.429495 0.390842 0.374855 0.382085 0.410038 0.454152 0.508697 0.567855 0.62646 0.680419 0.72677 0.76345 0.788918 0.801804 0.80072 0.784345 0.751751 0.70292 0.639275 0.564105 0.482585 0.401495 0.328525 0.271185 0 0 0.241367 0.280196 0.335791 0.399634 0.462162 0.51425 0.548619 0.560917 0.550284 0.519314 0.473438 0.419877 0.366363 0.319904 0.285791
0.440127 0.528733 0.60887 0.670998 0.708198 0.717185 0.698705 0.657264 0.600273 0.536779 0.476042 0.426199 0.393265 0.380545 0.388645 0.415805 0.458511 0.512345 0.572579 0.634674 0.694479 0.748222 0.792359 0.823449 0.838152 0.833465 0.807185 0.758526 0.68875 0.601645 0.503575 0.403215 0.310635 0 0 0 0 0.244372 0.320755 0.411018 0.502125 0.580825 0.63567 0.658786 0.647087 0.602711 0.532621 0.447443 0.359743 0.282071 0
0.443655 0.495865 0.543244 0.580564 0.6038 0.610848 0.601934 0.579583 0.548175 0.513176 0.480207 0.454147 0.438445 0.434775 0.443075 0.461855 0.488815 0.521443 0.557469 0.595146 0.633195 0.670507 0.705714 0.736763 0.760695 0.773741 0.771778 0.751107 0.70942 0.646735 0.566005 0.473395 0.377755 0.289725 0 0 0 0 0.258227 0.342403 0.438698 0.533059 0.61152 0.66241 0.678214 0.656789 0.601704 0.52165 0.429039 0.338028 0.262319
0.531035 0.541635 0.540863 0.529897 0.510785 0.486409 0.460378 0.436706 0.419334 0.41153 0.415304 0.430972 0.456983 0.490103 0.525925 0.559695 0.587185 0.605565 0.613965 0.613642 0.607685 0.600266 0.595618 0.596928 0.605417 0.619808 0.636346 0.649417 0.652658 0.640335 0.608775 0.557475 0.489615 0.411985 0.333975 0.266225 0 0 0 0.251892 0.317507 0.397308 0.479062 0.550216 0.599978 0.621122 0.611166 0.572733 0.513045 0.442653 0.373646
0.659465 0.646315 0.608705 0.552784 0.486322 0.417971 0.356477 0.30982 0.284358 0.284027 0.309751 0.359148 0.426648 0.50409 0.581734 0.649625 0.699065 0.724011 0.722083 0.695036 0.64854 0.591244 0.533325 0.484697 0.453236 0.443335 0.455078 0.484211 0.522915 0.561265 0.589135 0.598115 0.583195 0.543785 0.483875 0.411435 0.336985 0.271714 0 0 0 0.247561 0.302161 0.367797 0.434042 0.491043 0.531179 0.55024 0.547938 0.527691 0.495753
0.757115 0.744575 0.696835 0.621565 0.529027 0.431009 0.33968 0.266381 0 0 0 0.289512 0.374965 0.478158 0.586472 0.686263 0.764695 0.811587 0.820986 0.792169 0.729879 0.643713 0.546713 0.453351 0.377244 0.32895 0.314262 0.333279 0.380431 0.44547 0.515265 0.576065 0.615835 0.626305 0.604265 0.552025 0.476905 0.389827 0.303432 0 0 0 0 0 0.256414 0.324403 0.394988 0.459695 0.512119 0.548606 0.568341
0.770323 0.769444 0.733109 0.667782 0.582552 0.488182 0.396127 0.317443 0.261764 0 0.245031 0.288028 0.361281 0.456879 0.563745 0.668864 0.758888 0.821954 0.849419 0.837262 0.786868 0.705023 0.603077 0.495336 0.396923 0.321448 0.278858 0.273847 0.305099 0.365519 0.443417 0.524435 0.593925 0.639315 0.652085 0.629105 0.572935 0.491265 0.395479 0.298811 0 0 0 0 0 0 0.279671 0.361092 0.441994 0.514894 0.574273
0.697539 0.697042 0.673022 0.6308 0.576827 0.518014 0.461183 0.41263 0.377777 0.360829 0.364437 0.389343 0.434107 0.494951 0.56588 0.639105 0.705834 0.757354 0.786271 0.787731 0.760381 0.706858 0.633676 0.550444 0.468523 0.399285 0.352283 0.333648 0.344989 0.383049 0.440164 0.505486 0.566765 0.612375 0.633215 0.624235 0.585115 0.520355 0.438355 0.35006 0.267091 0 0 0 0 0 0.256505 0.329403 0.407169 0.482497 0.549416
0.587501 0.561733 0.530652 0.501159 0.478719 0.466691 0.466146 0.476147 0.494362 0.51781 0.543567 0.569268 0.593316 0.614807 0.633249 0.648196 0.65896 0.664492 0.663511 0.654854 0.63795 0.613279 0.582676 0.549341 0.517496 0.491733 0.476143 0.473411 0.484091 0.506224 0.535435 0.565531 0.589507 0.600815 0.594555 0.568565 0.523895 0.464815 0.398165 0.332275 0.275603 0 0 0 0.246085 0.289215 0.343855 0.403315 0.461315 0.512874 0.554846
0.503958 0.432347 0.370252 0.329385 0.317603 0.337756 0.387431 0.459576 0.543872 0.628542 0.702301 0.756071 0.784203 0.785043 0.7608 0.716837 0.660547 0.600078 0.543132 0.496033 0.463152 0.446729 0.446999 0.462538 0.49067 0.527864 0.570033 0.612744 0.651395 0.681403 0.698488 0.699085 0.680837 0.643125 0.587495 0.517855 0.440345 0.362735 0.293605 0.241095 0 0 0 0.282226 0.347835 0.421795 0.494445 0.556805 0.602065 0.626565 0.630265
0.482025 0.366375 0.264731 0 0 0 0.264921 0.375824 0.51054 0.650711 0.777453 0.87417 0.928914 0.935918 0.896144 0.816797 0.709975 0.590722 0.474823 0.376696 0.307649 0.274731 0.280215 0.32173 0.39289 0.484297 0.584722 0.682332 0.765855 0.825597 0.8543 0.847793 0.805424 0.730245 0.628895 0.511105 0.388895 0.275325 0 0 0 0 0 0.279583 0.393983 0.514365 0.625435 0.713345 0.767805 0.783505 0.761016
0.506392 0.373759 0.249569 0 0 0 0 0.291215 0.440575 0.605065 0.762382 0.891319 0.974854 1.00252 0.971721 0.887874 0.763346 0.61549 0.464078 0.328564 0 0 0 0 0.283693 0.399785 0.533154 0.667685 0.787511 0.878649 0.930361 0.936174 0.894481 0.808757 0.687275 0.542365 0.389325 0.244825 0 0 0 0 0 0 0.366972 0.523405 0.671865 0.793875 0.874545 0.904731 0.882411
0.525769 0.414484 0.303118 0 0 0 0 0.280905 0.409985 0.559415 0.708775 0.837393 0.927429 0.966505 0.949461 0.878979 0.765029 0.623269 0.472689 0.332903 0 0 0 0 0 0.347279 0.478808 0.61533 0.740691 0.840348 0.902802 0.920651 0.891265 0.816955 0.704785 0.565945 0.414775 0.267325 0 0 0 0 0 0 0.309064 0.468418 0.627462 0.766689 0.868953 0.921904 0.919805
0.49251 0.430469 0.365659 0.310905 0.278165 0.276465 0.310085 0.377565 0.471735 0.580605 0.689153 0.781734 0.8445 0.867659 0.847041 0.78477 0.688945 0.572336 0.450506 0.339448 0.253332 0 0 0 0.290003 0.382759 0.489694 0.597627 0.693858 0.767538 0.810659 0.818655 0.790615 0.729115 0.639965 0.531545 0.414165 0.299205 0 0 0 0 0 0 0.291102 0.415849 0.546023 0.666308 0.762138 0.821743 0.837933
0.399023 0.388627 0.382866 0.386329 0.403185 0.436095 0.485235 0.547735 0.617675 0.686705 0.745255 0.784053 0.795797 0.776606 0.726928 0.651765 0.560135 0.463745 0.375354 0.306676 0.266679 0.260195 0.287264 0.343245 0.419655 0.505585 0.589359 0.660255 0.709875 0.73308 0.728325 0.697425 0.644925 0.577145 0.501265 0.424375 0.352895 0.292185 0.246389 0 0 0 0.252407 0.300396 0.361801 0.431411 0.502736 0.568513 0.621504 0.655468 0.666182
0.28521 0.304845 0.343287 0.398821 0.468465 0.547865 0.631265 0.711665 0.781245 0.832145 0.857415 0.852167 0.81462 0.746832 0.654936 0.548757 0.440755 0.344405 0.272351 0 0 0.276597 0.351117 0.448826 0.555835 0.656985 0.738077 0.788012 0.800399 0.774334 0.714332 0.629395 0.531445 0.433335 0.346975 0.281575 0.242685 0 0.246319 0.281102 0.328945 0.382215 0.433903 0.478452 0.512177 0.533313 0.541756 0.538656 0.525981 0.506167 0.481907
0 0 0.284103 0.362931 0.462492 0.574255 0.688155 0.793355 0.879095 0.935735 0.955907 0.935559 0.874855 0.778638 0.656357 0.521339 0.389386 0.276869 0 0 0 0.247994 0.354388 0.487162 0.628075 0.757411 0.856839 0.912156 0.915419 0.866118 0.771227 0.644087 0.502305 0.365085 0.250325 0 0 0 0 0.289043 0.390048 0.492318 0.581482 0.646105 0.67903 0.677985 0.645443 0.58785 0.514416 0.435701 0.362219
0 0 0.262165 0.331335 0.425585 0.536686 0.654429 0.767432 0.864066 0.933576 0.967284 0.959676 0.909446 0.820077 0.699963 0.561867 0.421703 0.296717 0 0 0 0 0.318889 0.456686 0.609875 0.757276 0.877982 0.954459 0.975223 0.936654 0.843626 0.708834 0.550915 0.391655 0.252705 0 0 0 0 0.268836 0.394645 0.52671 0.645888 0.735749 0.78477 0.787666 0.745766 0.666426 0.561684 0.446391 0.336132
0.296579 0.292115 0.311285 0.353595 0.416325 0.494765 0.582522 0.671869 0.754295 0.821164 0.864539 0.878135 0.858283 0.804773 0.721393 0.616007 0.50004 0.387341 0.292509 0 0 0 0.298571 0.403958 0.532716 0.667261 0.788456 0.87846 0.923495 0.916085 0.856353 0.752148 0.617952 0.472725 0.337016 0 0 0 0 0.273261 0.3861 0.511786 0.631361 0.727387 0.786457 0.800955 0.769894 0.698733 0.598315 0.483095 0.36903
0.394608 0.401375 0.416085 0.438175 0.466755 0.500725 0.538765 0.579103 0.619448 0.656799 0.687506 0.707549 0.713071 0.701106 0.670379 0.621991 0.559796 0.490331 0.42221 0.365009 0.327802 0.317566 0.337774 0.387449 0.460909 0.548341 0.63712 0.713736 0.765978 0.785026 0.76703 0.713921 0.63324 0.536995 0.439787 0.356387 0.299351 0.276948 0.29184 0.340706 0.414867 0.501787 0.587177 0.657316 0.701223 0.712287 0.689129 0.635646 0.56017 0.474049 0.389857
0.454439 0.489627 0.520585 0.543865 0.557405 0.560955 0.556055 0.545725 0.533805 0.524061 0.519347 0.520943 0.528248 0.538909 0.549379 0.555774 0.554855 0.544901 0.526272 0.501501 0.4749 0.45171 0.436993 0.434494 0.445723 0.469478 0.501929 0.537275 0.568851 0.590467 0.597693 0.588842 0.56539 0.531775 0.494565 0.461149 0.438299 0.430723 0.440085 0.464598 0.499297 0.536965 0.569511 0.589537 0.59179 0.574214 0.538385 0.489308 0.434515 0.382789 0.34264
0.450781 0.511006 0.565418 0.606745 0.629485 0.630885 0.611485 0.575055 0.528061 0.478523 0.434663 0.403496 0.389631 0.394543 0.416421 0.450618 0.490616 0.529273 0.56014 0.578553 0.582336 0.571964 0.550223 0.521461 0.49061 0.462216 0.43968 0.424844 0.417981 0.418149 0.423767 0.433242 0.445465 0.460037 0.477175 0.497315 0.52059 0.54619 0.57206 0.594818 0.610127 0.613429 0.600923 0.570593 0.523033 0.461869 0.393604 0.326908 0.271362 0 0
0.407285 0.465827 0.52738 0.583181 0.624925 0.646185 0.643585 0.617445 0.571905 0.514198 0.453575 0.399687 0.360993 0.343352 0.349087 0.376687 0.421173 0.475043 0.529608 0.576446 0.60873 0.622181 0.615531 0.590451 0.551012 0.502849 0.452201 0.405019 0.366298 0.339689 0.327387 0.330233 0.347914 0.379152 0.421812 0.472905 0.528555 0.583894 0.633287 0.670583 0.689776 0.685846 0.655736 0.599266 0.519759 0.424204 0.322806 0 0 0 0
0.377367 0.397959 0.433723 0.479062 0.526502 0.568025 0.596525 0.607165 0.598255 0.571568 0.532047 0.486825 0.443945 0.410877 0.393195 0.393643 0.411737 0.443972 0.484546 0.526459 0.562742 0.587592 0.597223 0.590299 0.567926 0.533274 0.490925 0.446128 0.404104 0.369479 0.345938 0.336044 0.341191 0.361605 0.396326 0.443154 0.498565 0.557695 0.614465 0.661891 0.692822 0.700731 0.680902 0.631447 0.554186 0.455058 0.343918 0 0 0 0
0.403269 0.361509 0.341482 0.345021 0.370031 0.411066 0.460493 0.509975 0.551965 0.580979 0.594336 0.592341 0.57788 0.555584 0.530741 0.508227 0.491631 0.482756 0.481538 0.486353 0.494591 0.503343 0.51004 0.512906 0.511167 0.505018 0.495389 0.483631 0.471223 0.459562 0.449891 0.443334 0.440978 0.443916 0.453181 0.469524 0.493058 0.522855 0.556575 0.590365 0.619015 0.636485 0.63692 0.615679 0.570551 0.502712 0.417193 0.32273 0 0 0
0.48247 0.380492 0.296654 0.24147 0 0 0.280638 0.348817 0.429425 0.511534 0.585241 0.642951 0.680046 0.695051 0.689277 0.666152 0.630373 0.587108 0.541346 0.497469 0.459044 0.428787 0.408592 0.39957 0.402034 0.415438 0.438292 0.468145 0.501699 0.53509 0.564351 0.586004 0.597653 0.598468 0.58942 0.573162 0.55356 0.534922 0.521055 0.514365 0.515195 0.521585 0.529505 0.533655 0.528588 0.510061 0.476181 0.428251 0.370978 0.311988 0.260683
August 13, 2010 12:57am UTC in response to fenn pig
Re: format of interpolation function data file
Hi Fenn,
I'm having the exactly same problem. I get the following error from COMSOL v4: "Format of the data file is not correct".
Did you solve this problem?
Andre
%Grid
0.00008120 0.00024360 0.00040600 0.00056840 0.00073080 0.00089320 0.00105560 0.00121800 0.00138040 0.00154280 0.00170520 0.00186760 0.00203000 0.00219240 0.00235480 0.00251720 0.00267960 0.00284200 0.00300440 0.00316680 0.00332920 0.00349160
%Data
1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000 1.00000000
August 13, 2010 8:28pm UTC in response to Andre Teves
It is working for me now, I was making a mistake in the dimension of the data function.
Rules and guidelines
