Filter by Topic
Release
Popular Topics
- List all discussions
converting COMSOL code to the MATLAB ???
April 26, 2012 1:21pm UTC
I'm working with COMSOL to simulate a chemical experience, but it takes too much time to display the results.
So i want to find a link between comsol and matlab if i can convert the code of comsol to matlab that will be faster than using comsol alone !!!
So am asking if i can do this and how ????
watting your answer
thank you very much :)
April 26, 2012 1:31pm UTC in response to Mariem Nefzi
Re: converting COMSOL code to the MATLAB ???
you can simply save your comsol model as a MATLAB m.file
In the comsol file menu/ save As model mfile
April 26, 2012 1:50pm UTC in response to Mohammad Goharkhah
hi Mohammad ,
thank so much for your attention . i juste did what you say but when I execute the code in matlab, it doesn't work against in comsol it works very good !!
You can find out how I can solve this problem ?
thank's again
April 26, 2012 2:00pm UTC in response to Mariem Nefzi
Before executing the code in MATLAB, you should "run comsol with matlab"
go to the start menu/All programs/ comsol/ run comsol with matlab
then, you can run the mfile
April 27, 2012 7:09pm UTC in response to Mariem Nefzi
here are the steps:
Step in Comsol:
- save model as .m
Start 'Comsol with Matlab'
Steps in Matlab:
- open the .m
- put first and last lines of the code in comments:
% function out = model
...code...
% out = model;
- at the end of the code, insert lines to extract results, here is an example for heat transfer, see the docs for mpheval:
T = mpheval(model,'T') % temperature
kx = mpheval(model,'ht.kxx') % thermal conductivity in x
- Run your .m (F5) and see the extracted data in the matlab workspace
- The postprocessing world is yours!
June 1, 2012 2:20pm UTC in response to Francois Gregoire
Thanks.Good Hints.
Rules and guidelines
