Filter by Topic
Release
Popular Topics
- List all discussions
Cluster job that shows speed-up when using multiple nodes
May 16, 2012 8:51pm UTC
I would be highly interested if someone could post an mph model file that they have shown to see speed-up when distributed across multiple nodes. I am having difficulty seeing any speed up for a number of models and understand from previous threads that speed-up is highly model dependent.
If someone could post an mph file that they know to show speed-up it would be greatly appreciated.
Josh Thomas
October 4, 2012 5:14pm UTC in response to Josh Thomas
Re: Cluster job that shows speed-up when using multiple nodes
Dear Josh,
unfortunately I have not read your post earlier: hope it's not too late!
The models that you have tested are provided to test proper operations of the cluster, not performance. For performance, you'd better try to reproduce the results of the following paper, based upon models also available in the model library, for the same number of DOFs: www.comsol.fr/papers/10248/
Stephan
www.comsol.fr
January 29, 2013 9:59pm UTC in response to STS
Stephan,
Thanks for the reply. I did have a chance to review Freels work and get comparable speed-up results for some of my own large memory models (upwards of 2.5 MDoF). Part of the issue was getting our HPC system interfacing properly with the COMSOL batch commands and PBS scheduler for optimal advantage of the cluster. The other part related to what you brought up about using a good test model. I've seen that until my models go beyond 1 or 2 MDoF that the speedup is minimal across clusters. But, in those cases, my workstation works great for these anyways!
Thanks again for the reply,
Josh
Rules and guidelines
