Combining particle tracing and rotating machinery modules
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   2 Replies   Last post: April 30, 2014 5:32pm UTC
Scott Hug
Scott Hug
August 29, 2012 8:47pm UTC
HOw do I combine the particle tracing and rotating machinery modules so that they can run simultaneously in a study? I am attempting to study the particle trajectories in a 3-D mixer (the same mixer design that is used in COMSOL's "Baffled Mixer" model).
When I run a study using both the rotating machinery and particle tracing modules, I will get a message that says Failed to find consistent initial values.
Last time step is not converged..
I never get convergence when I run the teo modules at the same time, but I get convergence no problem if I run either of the modules by itself. Is there a setting I would have to change?
Sylvana Garcia
Sylvana Garcia
May 17, 2013 6:55pm UTC in response to Scott Hug
Re: Combining particle tracing and rotating machinery modules
I am also trying to model particles in a mechanical mixer. I first solved for the velocity field and then ran the Particle Tracing Module. It worked ok for the first time steps, but the particles seemed to freeze once they reached the impeller blades. These boundaries have a bounce boundary condition, so the particles should not freeze. Any tips anyone? Has anyone managed to successfully model particles in a stirring tank?
Thank you.
Anna Koontzvitzki
Anna Koontzvitzki
April 30, 2014 5:32pm UTC in response to Sylvana Garcia
Hi, Have you found a solution?
Rules and guidelines
