Filter by Topic
Release
Popular Topics
- List all discussions
Conjugate heat transfer Interface boundary condition
October 2, 2012 11:25am UTC
Hello All,
I am new to COMSOL. I am trying to solve a 3-D conjugate heat transfer problem with volumetric heat generation in the solid domain. The problem is more like solving for a temperature profile in a heat exchanger. how and what should be the boundary condition applied for the fluid-solid interface?
rgds
Anup
October 2, 2012 12:09pm UTC in response to Anup Paul
Re: Conjugate heat transfer Interface boundary condition
COMSOL imposes temperature continuity at the fluid-structure boundary in a conjugate heat transfer problem. There is no need for a different thermal boundary condition there. That boundary condition accounts directly for heat loss from the solid through conduction and the fluid flow that results accounts for convection.
Nagi Elabbasi
Veryst Engineering
October 3, 2012 5:45am UTC in response to Nagi Elabbasi
thanks ....thanks a lot.
rgds
Anup
November 4, 2012 11:03am UTC in response to Anup Paul
Daer Nagi
Its fine that comsol itself taking care of interface boundary condition as heat loss from the solid. However, in my problem the solid is under laser heating (consider as a volumetric heat generation based on Beer-Lambert law)in which i am defining optical properties for solid as well as for fluid such that fluid light absorption characteristic is greater than that of solid. I should get a maximum temperature in the fluid domain not in the solid domain because of higher light absorption characteristic of fluid. But , results shows exactly opposite. The max temp is obtained at the solid domain rather than fluid. If my explanation is correct, how to resolve this issue?
rgds
Anup
November 4, 2012 6:10pm UTC in response to Anup Paul
Hi Anup,
Whether solid or fluid gets higher temperature depends also on the distance the laser travels through them as well (not just their absorption characteristics). I don’t think any special treatment is needed at the fluid-solid boundary. You just need to add the volumetric heat source to fluid and solid domains separately.
Nagi Elabbasi
Veryst Engineering
November 9, 2012 1:20pm UTC in response to Nagi Elabbasi
thanks
rgds
Anup
February 15, 2013 5:55am UTC in response to Nagi Elabbasi
Dear Nagi,
I need an immediate help for the thread : www.comsol.com/community/forums/general/thread/34647/
I am somewhere stuck up in meshing part, thus, request you to please reply.
Ishant Jain
Rules and guidelines
