Discussion Forum
COMSOL solver control
Topics: 4.3a
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   5 Replies   Last post: February 10, 2013 5:16pm UTC
Hamsa Dhwani
Hamsa Dhwani
October 15, 2012 2:37pm UTC
I am looking at a problem that solves physics at two different time scales. Basically, I want to do the following
At a coarser time scale I want to solve a few partial differential equations (PDEs).
In each coarse time step, the source terms and some coefficients for these PDEs have to be determined by solving a few other PDEs with shorter time steps. The physics at the finer time scale will be solved for a few time steps and then eventually when the fine time scale agrees with the coarser time, the coefficients and source terms are updated. An algorithm will be
For CoarseTimeStep = 1 to n
for FinerTimeStep = 100 smaller time steps in each coarseTimeStep
solve PDE_SET_1 to get coefficients and source terms
end
Use these coefficients and source terms to solve PDE_SET_2
end
Can someone suggest if this is possible to do in comsol? If so, can you kindly point me to appropriate resources.
Hamsa
Jesus Lucio
Jesus Lucio
October 15, 2012 4:33pm UTC in response to Hamsa Dhwani
Re: COMSOL solver control
Hi, Hamsa,
This algorithms including COMSOL solvers could be done through MATLAB (you need LiveLink for MATLAB) or Java.
Bye,
Jesus
Hamsa Dhwani
Hamsa Dhwani
October 15, 2012 4:37pm UTC in response to Jesus Lucio
Hi Jesus,
Thanks for your prompt email. Can you point me to a tutorial or a sample program that does something of this sort?
Hamsa
Hi, Hamsa,
Bye,
Jesus
Jesus Lucio
Jesus Lucio
October 15, 2012 5:11pm UTC in response to Hamsa Dhwani
Hi, Hamsa,
You should read the corresponding documentation:
COMSOL LiveLink™ for MATLAB® Introduction and User’s Guide, and also you can look (from MATLAB) at several simple models saved as .m
I spent much time in using MATLAB with COMSOL up to 3.5, but I don't use MATLAB with COMSOL now.
Once you have read that documentation, many people in this forum will be able to help you in particular points.
Bye,
Jesus.
Hamsa Dhwani
Hamsa Dhwani
October 15, 2012 5:36pm UTC in response to Jesus Lucio
Thanks for your prompt reply Jesus. I am going to do some search on this. Thanks for your help.
Hamsa
Xu Gong
Xu Gong
February 10, 2013 5:16pm UTC in response to Hamsa Dhwani
Dear Hamsa:
I got a quite similar problem with yours. I was wondering if you solved this. We can discuss about it. Thank you!!!!
Xu
Rules and guidelines
