Discussion Forum
Enforcing variables to be greater than or equal to zero
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   2 Replies   Last post: December 3, 2012 3:19pm UTC
Alistair Kirk
Alistair Kirk
December 2, 2012 11:29pm UTC
I'm modelling diffusion through a porous medium with adsorption. The main dependent variable for mass concentration tends to go below zero which is not true in reality. Is there a way to enforce my variables to be >=0 at all times?
I would also like to apply this condition to other concentrations that I specify in my additional variables.
Any suggestions would be greatly appreciated.
Sergei Yushanov
Sergei Yushanov
Certified Consultant
AltaSim Technologies, LLC
December 3, 2012 3:13pm UTC in response to Alistair Kirk
Re: Enforcing variables to be greater than or equal to zero
Alistair,
To enforce variables to be >=0 at all times, use Segregated solver. Then, right-click Segregated 1 node and add Lower Limit node. In the Settings window for Lower limit, you can define lower limits for your field variables.
Good luck,
Sergei Yushanov
Ivar Kjelberg
Ivar Kjelberg
December 3, 2012 3:19pm UTC in response to Alistair Kirk
normally it's far better to understand why you get "non physical values"
Mostly it's because of non physical initial conditions or inappropriate meshing densities around steep dependent variable values, once these are corrected the solution is far more robust
Rules and guidelines
