Discussion Forum
Parallel computing MatLab Comsol
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   6 Replies   Last post: February 13, 2013 6:00pm UTC
Anders Gudmarsson
Anders Gudmarsson
December 6, 2012 8:24am UTC
I am using Comsol 4.3 with Livelink for Matlab. I run an optimization code in Matlab where i call Comsol to perform frequency response simulations. Now i would like to start two parallel frequency response simulations that are independent of each other from my Matlab code.
My approach so far has been to open another Matlab worker by using matlabpool and parfor. However, only one of the Matlab workers are then connected to Comsol. Is it possible to perform parallel computing in Comsol when using the Matlab livelink?
//Anders
Hamsa Dhwani
Hamsa Dhwani
January 31, 2013 3:19pm UTC in response to Anders Gudmarsson
Re: Parallel computing MatLab Comsol
Hi Anders,
Were you able to solve this problem?
I am trying to do the following
parfor k=1:20
model2 = mphload('micromodel');
end
This should initiate several parallel comsol instances in matlab. However, I get the following error
Error using parallel function
Undefined variable "ModelUtil" or "ModelUtil.load"
However if I do this in serial:
parfor k=1:20
end
it works fine.
Anders Gudmarsson
Anders Gudmarsson
February 5, 2013 3:14pm UTC in response to Hamsa Dhwani
Hi Hamsa,
Yes I managed to find a solution to this problem.
To connect the matlab workers to comsol i use the system command below to start a server for each worker. Then i use the mphstart command to connect my parallel functions to the comsol servers by specifying the ports.
comsolPort = 2036;
system( ['comsol -np 1 server -silent -port ' num2str(comsolPort) ' &'] );
mphstart( comsolPort )
import com.comsol.model.*
import com.comsol.model.util.*
I hope this will help you.
Anders
Hamsa Dhwani
Hamsa Dhwani
February 5, 2013 5:03pm UTC in response to Anders Gudmarsson
Hi Anders,
Thanks for your reply. I am able to launch comsol on the workers, however, they are not able to finish off normally. Somhow they end up crashing.
Can you tell me if you use labBarriers, LabSend and LabReceive commands to communicate from the parent process to the worker processes?
Also, would I be right in making the parent do the writing to the files etc. and just get the data from the child processes?
Julian Freed-Brown
Julian Freed-Brown
February 8, 2013 5:33pm UTC in response to Anders Gudmarsson
Hi Anders,
I'm having the same problem you started with, but I'm not quite following how you solved it.
Could you please upload some sample code that show how you fixed the problem? I'd really appreciate it.
-jfb
Anders Gudmarsson
Anders Gudmarsson
February 13, 2013 9:50am UTC in response to Julian Freed-Brown
Here is a sample code of my solution to this problem.
I use the system command to start comsol and then i call my comsol functions in the parfor loop.
matlabpool open 2
comsolPort = 2036;
pause( 6 )
comsolPort = 2037;
pause( 6 )
parfor i = 1:2
if i == 1
y_acc_amp_final{i}=Torsion(dataT,f_range);
else
x_acc_amp_final{i}=Long(dataT,f_range);
end
end
matlabpool close
In my comsol functions i use the mphstart command to connect the functions to the opened comsol ports.
cd('C:\Program Files\COMSOL43\mli')
mphstart(2036)
I hope this may be helpful.
Anders
Julian Freed-Brown
Julian Freed-Brown
February 13, 2013 6:00pm UTC in response to Anders Gudmarsson
Thanks so much for your help! I got it working.
Thanks again,
-jfb
Rules and guidelines
