Filter by Topic
Release
Popular Topics
- List all discussions
Boundary conditions in the tutorial model (Periodic boundary conditions)
December 10, 2012 11:54am UTC
Hi all,
I have question regarding the boundary conditions used in the tutorial model about periodic boundary conditions. In this model a plane wave with a wave-vector with non-zero x- and z-component and polarisation in y-direction should be modelled. At the top and bottom boundary scattering boundary conditions are used in order to allow an excitation. And for the boundaries with a normal vector in x-direction Floquet periodic condition are used. But for the ones with a normal vector in y-direction perfect elector conductor is used. Can someone explain to me, while for these boundaries not also periodic conditions are used (Floquet or Continuity (as ky=0))?
(I tried to make the simulation using periodic conditions for all sides and the results are more or less the same. I'm just wondering if there is any reason why in the tutorial model perfect electric conductor is used, which may be important in some more complex geometries.)
Thanks a lot in advance,
Felix
December 11, 2012 10:39pm UTC in response to Felix
Re: Boundary conditions in the tutorial model (Periodic boundary conditions)
For the particular polarization used in the example, PEC boundary condition works. For orthogonal polarization, the BC should be change to PMC. For the general case is always better to use Floquet BCs.
December 12, 2012 4:38pm UTC in response to Alexander Kuznetsov
Thanks a lot for your explanation
Rules and guidelines
