Discussion Forum
Cement flowing around funky 3D shape and displacing mud
Topics: Physics, Fluid Flow, CFD, 4.3
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   2 Replies   Last post: February 3, 2013 11:11pm UTC
John Lovell
John Lovell
December 12, 2012 6:22pm UTC
Hi, I have an interesting fluids problem. 3D object in a snug fit inside a water filled tube. Pump heavy cement in one end, will it displace all of the water as it flows around the object or leave some trapped fluid.
Any recomendations on a CFD module to use?
Regards, John
David Kan
David Kan
COMSOL Employee
USA
December 19, 2012 6:19pm UTC in response to John Lovell
Re: Cement flowing around funky 3D shape and displacing mud
Hi John,
I heard back from one of our in-house experts and here are some snippets:
> This sounds difficult. The implementation would need a two-phase flow, where one of the phases (cement) is a non-newtonian fluid. Whether to use level-set, phase-field or euler-euler is not clear to me. Which thixotropy model to use for the concrete is also a research area.
How well the COMSOL solvers are suited for this task is also unknown. But you can give it a try!
David
John Lovell
John Lovell
February 3, 2013 11:11pm UTC in response to David Kan
Hi, I found some empirical information that may significantly simplify the problem. for a first order approximation: if the flow is turbulent then the cement slurry will displace the drilling mud. So the problem becomes one of 3D flow to identify whether any zones around the object will have only laminar flow,
What I think would then be valid is to assume turbulent flow, solve with k-e, find the lowest Reynolds number, and check that the Re is large enough that the turbulent assumption is valid. Do you agree?
Regards, John
Rules and guidelines
