Discussion Forum
How to include anisotropy in the solid mechanics module
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   3 Replies   Last post: January 14, 2013 3:29pm UTC
John R Puentes
John R Puentes
January 10, 2013 5:04pm UTC
I am working on a model, simulating an anisotropic material that shrinks and warps due to changes in temperature. I wonder how can I include an initial temperature (thermal strain) in the structural mechanics module? Do I need to use the structure-heat transfer coupling? Is there any way that I can add a constant temperature as the load in the structural mechanics module?
Nagi Elabbasi
Nagi Elabbasi
Certified Consultant
Veryst Engineering
January 10, 2013 8:57pm UTC in response to John R Puentes
Re: How to include anisotropy in the solid mechanics module
Hi John,
If the temperature is constant it is simpler to not use the heat transfer physics. You can account for the thermal strains using the “Thermal Expansion” sub-node under elastic materials or using the “Initial Stress and Strain” sub-node and manually setting initial strain equal to CTE*(T-T_Ref).
Nagi Elabbasi
Veryst Engineering
John R Puentes
John R Puentes
January 14, 2013 3:04pm UTC in response to Nagi Elabbasi
Thanks Nagi,
I have one more question regarding anisotropy, how does COMSOL treat the local and global coordinates in anisotropic models? In anisotropic models is important to be able to impose different local coordinates depending on the orientation of the fibers. Does COMSOL have options for local coordinates in curves and irregular shapes? Where can I find more information about the use of local and global coordinates in anisotropic models?
Nagi Elabbasi
Nagi Elabbasi
Veryst Engineering
January 14, 2013 3:29pm UTC in response to John R Puentes
For curved geometries you can setup a Base Vector System in the Definitions node and refer to it in the Coordinate System Selection of the material model you are using. The manuals contain some examples.
Nagi Elabbasi
Veryst Engineering
Rules and guidelines
