Discussion Forum
how to measure max and min electric field of certain surface area ?
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   2 Replies   Last post: February 10, 2013 2:31am UTC
Hadi Afrouzi
Hadi Afrouzi
January 15, 2013 7:48am UTC
I simulated the insulation with a void , ( rectangular and circle) in 2D.
any way I want measure the max and min of electric field on the surface of the circle (certain surface) then how can I do THIS?
I can measure max and min in whole surface of my geometry but I need measure just at void surface.
thanks in advance
Ivar Kjelberg
Ivar Kjelberg
January 15, 2013 1:04pm UTC in response to Hadi Afrouzi
Re: how to measure max and min electric field of certain surface area ?
you have the min max plot option on a surface OR on a line or ..., but this will by default check all surfaces and all lines ... So you should make a subset with a Results - Data Set - select surface or select line and apply the min max plot thereon.
You can also use a Derived values node on a selection and ask for the min manx. Check the forum how to dump also the x,y,z location of the min aor max value
Hadi Afrouzi
Hadi Afrouzi
February 10, 2013 2:31am UTC in response to Ivar Kjelberg
Dear Ivar
Thank you for you reply.
Rules and guidelines
