Discussion Forum
When I have to use 2d or 3d modeling?
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   2 Replies   Last post: January 20, 2013 9:38pm UTC
Wagner Gurgel do Amaral Filho
January 17, 2013 10:06am UTC
Hi Everybody!
I´m Wagner, from Brazil and I have a question, a simple question I think!
How I decide if my modeling will be in 2d or in 3d?
I have Heat Transfer and AC/DC model and I work calculating and projecting Electrical Equipament, like Transformers, Reactor, Harmonic Filters and more...
Someone here have this knowledge?
Thank you for your time.
Best Regards,
Wagner.
Ivar Kjelberg
Ivar Kjelberg
January 17, 2013 1:59pm UTC in response to Wagner Gurgel do Amaral Filho
Re: When I have to use 2d or 3d modeling?
first of all, 2D is far "easier" = lighter w.r.t. RAM and resources, hence solves much faster. But 2D or 2D-axi means that you model have given plane or axial cylindrical symmetry. This is not always the case, so it all depends.
my way is to start as far as possible with simple 2D or 2D-axi models. Once these work I go to full 3D models and only if I really need to
Miroslav Jicha
Miroslav Jicha
January 20, 2013 9:38pm UTC in response to Wagner Gurgel do Amaral Filho
generally you can neglect any direction in situations when there is no heat flux in this particular direction, in other words there is no significant temperature difference or gradient in this direction. Typical is cylindrical symmetry but only when there is no "azimutal" change (for example one half of the cylinder is heated the other side cooled). And when the cylinder is very long, probably the heat flux in the axial direction can be neglected, because the thermal resistance in this direction is so large that it does not allow any heat to flow in this direction. So it sometimes a trade off and a matter of simplification.
Miro
Rules and guidelines
