Filter by Topic
Release
Popular Topics
- List all discussions
Issue importing ipt files from Inventor with the CAD module
January 22, 2013 6:42pm UTC
I can't seem to import a simple IPT cad file (that has a helix built in) from inventor, the import module gives me an error back saying:
Not a valid ENTITY type for this operation
- Detail: Internal_error_translating_CAD_model
- Detail: File version is not supported
- Filename:...
Is there any version limitation on inventor files or would that be something else?
Thanks in advance,
Matthieu
May 2, 2013 2:34pm UTC in response to Matthieu Dalban-Canassy
Re: Issue importing ipt files from Inventor with the CAD module
Hi all,
Got the same problem than you, except this time it is for a .SLDASM file created with SolidWorks...
Could anyone help us ?
Thanks in advance,
Etienne
May 2, 2013 8:40pm UTC in response to Etienne Buessler
A torus and worse helix's are tricky geometries many kernels do a poor job generating them.
Have you tried to play with the kernel option (COMSOL or the CAD too one ?
Else is it possible to reconstruct the helix with COMSOL, you can make hybrid CAD, partly imported, partly reconstructed locally (at least that works OK for me in SolidWorks. But I have always been critical with Bezier curves and splines, these often translate badly into 3D surfaces when exporting (also between CAD systems I have noticed
Sometimes a SolidWorks file is read-in cleaner when saved as a Parasolid file (*.x_t) or when moving back in version ;)
Rules and guidelines
