Discussion Forum
electrostatic force cause displacement in parallel plate capacitor in COMSOL
Topics: 4.0, AC/DC Module
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   16 Replies   Last post: March 22, 2013 4:26pm UTC
Suzan Miah
Suzan Miah
January 23, 2013 3:50pm UTC
I have been designed a parallel-plate capacitor in COMSOL. Where one plate is connect to voltage of 10V and other one is connected to GND. and a air box is around the parallel plate capacitor.
As I know, if I applied a voltage in plate 1 then there will displace in plate one. I want to know how can I measure and plot this displacement of the plate. I have been stooped here for couple of week.
Would any one please help me in this regard.
Thank in Advance.
-Suzan
Luke Gritter
Luke Gritter
Certified Consultant
AltaSim Technologies
January 23, 2013 4:39pm UTC in response to Suzan Miah
Re: electrostatic force cause displacement in parallel plate capacitor in COMSOL
Suzan,
You can model the deflection by coupling Electrostatics, Solid Mechanics, and Moving Mesh interfaces. Use the Maxwell surface stress tensor for the boundary load on an electrically conducting material. I've attached an example model showing the implementation. If the deflection is very small compared to the gap, the Moving Mesh interface would not be required, as the electrostatic force would not vary significantly with the displacement.
Luke Gritter
Attachments:   2D Diaphragm Deflection.mph
Suzan Miah
Suzan Miah
January 23, 2013 4:45pm UTC in response to Luke Gritter
Thank you very much for your kind response..:)
Hope it will help me
Suzan Miah
Suzan Miah
January 27, 2013 12:38pm UTC in response to Suzan Miah
I used Electromechanic physic..but there is some error . they need young's modulus and poission ratio of air.
As we know that air has no Young's modulus and poission ratio.
How can I overcome from this problem. Would anyone tell me.
Thanks in advance
Suzan Miah
Suzan Miah
January 27, 2013 12:45pm UTC in response to Suzan Miah
I also need use vacuum...would any one tell me from where I can get vacuum ?
Ivar Kjelberg
Ivar Kjelberg
January 28, 2013 12:34pm UTC in response to Suzan Miah
EMI is ES (static) and Solid together, you must add Domain nodes to distinguis "Linear Elastic Material" (without voltage solving) and "Linear Elastic Dielectric" (for solving with V i.e,.) by defining correctly the domains of solid as Linear Elastic material, you will not be asked for the Young modulus of air = linear electric material.
Note this physics module does not solve for conduction, so you need to define your GND and Terminal at the interface between solid (Linear Elastic Material), Linear Electric and/or Linear Ealstic Dielectric materials. Check carefully your doc
by the way this applies in my 4.3a version might be less rich in the previous ones
Dolu Rex
Dolu Rex
March 3, 2013 9:39pm UTC in response to Luke Gritter
Suzan,
Luke Gritter
I'm working on COMSOL 4.0a and I'm trying to compute a piece of PDMS which is compressed between two gold plates electrostatically actuated. I add two phisics Electrostatic and Solid. The electric field is correct but I don't get any displacement. Can someone help me please. I tryed to chek on Luke's code but I can not open it. I add mine to this message.
Thanks for the help!
Dolu
EDIT:
I add the moving mesh
Attachments:   test1.mph
Mohamed Hadj Said
Mohamed Hadj Said
March 20, 2013 5:39pm UTC in response to Dolu Rex
Hello dolu rex,
me too i have the same probleme
Mohamed Hadj Said
Mohamed Hadj Said
March 20, 2013 5:45pm UTC in response to Dolu Rex
did you find the displacement ????? can someone help me to find the displacement due to th electrostatic force between the 2 paralelle plate capacitor (the file is attached) thank you for ur help.
Attachments:   electro.mph
Ivar Kjelberg
Ivar Kjelberg
order is important, also for the physics nodes !
ALE and solid interact: you should put the ALE BEFORE=ABOVE Solid physics node in the node list, as "solid" has it's own frame representation that is equivalent to ALE and disables the ALE physics for the "solid" domain.
If you put ALE after solid you double lock the solid mesh, no good ;)
Then you calculate the forces in the ES but you have no boundary load force input in your solid. You must couple manually i.e. define the output of one and the input nodes to the other physics, and ensure the variables point to each other
Dolu Rex
Dolu Rex
March 21, 2013 10:58am UTC in response to Ivar Kjelberg
I reordered the nodes but now the program tells me that there is duplicate variable names. I thought it was because I deleted physics and add other so I made a new file but it still doesn't work.
Also is the order right now? -> electrostatics with the calculus of the force -> Moving mesh with free deformation and then -> the solid node with a boundary load with the ES force computed before to applie on the solid.
Thanks for the help.
Dolu
Attachments:   test2.mph
Mohamed Hadj Said
Mohamed Hadj Said
March 21, 2013 1:33pm UTC in response to Dolu Rex
thank you ivar, i find the displacement now i want to find the eign frequency when DC bias applied between the beam and the ground, to see the influence of the electric field. please if someone have idea tell me what can i do
thank you for your help
Mohammad Kamal
Mohammad Kamal
Could you please share your updated model
Ivar Kjelberg
Ivar Kjelberg
the eigenfrequency analysis is not influenced by forces, at best by some initial stress in your material. In your case you have a non-linear force applying on the plates so the eigenfrequency will be influenced in a non linear way, but this is not caught by a linear eigenfrequency analysis, and I believe the frequency you look for depends on the amplitude.
That is far trickier, one way is to run a time series with enough resolution (long time to wait, and let the system damp down from an oscillatory starting point, and do an running FFT on that result)
Mohamed Hadj Said
Mohamed Hadj Said
March 22, 2013 11:10am UTC in response to Mohammad Kamal
Hi Mohamed Kamel,
the samples is attached just delete the step2 of analysis eigenfrquency then doying the study, then you get the deformation rapidshare.com/#!download|982p...antileverBeam_mod.mph|6079|0|0
Unfortunately I couldn't upload the file in the forum because of the size limitation.
Mohamed Hadj Said
Mohamed Hadj Said
March 22, 2013 11:17am UTC in response to Ivar Kjelberg
Hi ivar
thank you for your help so i changed my study to : step1:stationary, step2: time dependant modal and next the study???
Mohammad Kamal
Mohammad Kamal
You can upload larger file. see the following link:
www.comsol.com/support/knowledgebase/1098/
Rules and guidelines
