Discussion Forum
Variable heat capacity
Topics: Heat Transfer, 4.3a
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   1 Reply   Last post: January 30, 2013 6:13pm UTC
Marko Pavlin
Marko Pavlin
January 30, 2013 5:45pm UTC
Hi!
I have measured Cp for metal alloy. It has significant temperature dependence. Is it possible to use Cp(T) instead of constant Cp for transient heat transfer problems?
Thanks!
Ivar Kjelberg
Ivar Kjelberg
January 30, 2013 6:13pm UTC in response to Marko Pavlin
Re: Variable heat capacity
Ccertainly, if you look carefully in the default materials there should be some with T and others even with pA dependence of the material properties.
You add an imported interpolation function (under the maerial node) to mimic your Cp(T) dependece, just be sure you get the SI units correct
When you have added your material to your model, and finme tuned it, you might save it in your own "private" material library for laer retrival
Rules and guidelines
