Discussion Forum
How to integrate a table result
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   5 Replies   Last post: March 29, 2013 8:36pm UTC
Daniel Lewis
Daniel Lewis
January 31, 2013 4:09am UTC
I have calculated surface integrals for total flux over particular features in my geometry. This outputs a table of total flux in (mol/s) vs. time points. I would like to then be able to integrate this vs. time to output a table of total mol vs. s but I cannot figure out how to integrate table data. Thanks!
Ivar Kjelberg
Ivar Kjelberg
January 31, 2013 5:49am UTC in response to Daniel Lewis
Re: How to integrate a table result
in the later versions (I do not believe it was in the early 4.0) you have table operations such as integration, sum, average ... on the columns
Else you must create your variable, even make a new global variable and integrate this way over the time (valid for time/transient solving)
Daniel Lewis
Daniel Lewis
January 31, 2013 5:54am UTC in response to Ivar Kjelberg
Thanks! This helped.
Jeffrey Fong
Jeffrey Fong
March 28, 2013 7:23am UTC in response to Ivar Kjelberg
I created a Global Evaluation for Power as a function of time but when I try to use the Data Series Operation - Integral, I get an error message saying "Table input type 'Time' does not match data input type 'Stationary'. Try evaluating in another table." But the data set is from a Time dependent analysis, so what would I be missing here?
Jeffrey
Ivar Kjelberg
Ivar Kjelberg
March 28, 2013 5:04pm UTC in response to Jeffrey Fong
Could it be the study pointer going to a wrong Data Set, or a leftover, sometimes its better to clear the table if it exist from before.
Or that you solution has not solved OK, in which case COMSOl is in default time series t=0 mode, and will go out of this state once the solver has finished in stationary (could also be a a "subversion 0" effect ;)
Jeffrey Fong
Jeffrey Fong
March 29, 2013 8:36pm UTC in response to Ivar Kjelberg
Hi Ivar,
I deleted all previous solutions and it worked.
Jeffrey
Rules and guidelines
