Discussion Forum
Comsol 4.3a Memory problem -- not using enough RAM
Topics: 4.3a
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   2 Replies   Last post: February 4, 2013 2:51pm UTC
Deepu Kumar
Deepu Kumar
February 4, 2013 12:07am UTC
Hello everyone,
Usually the complain is that Comsol is using too much memory, but in my case its other way round.
I have a really nice machine in the lab with windows 8 server. I have Comsol version 4.3a installed. I am trying to run an RF module computation, where I am trying to create a fine mesh.
My problem is that even though the computer has 256 GB or RAM, the comsol uses only 1.2 GB or so maximum. Also, I have a 16 core x 2 processor but it uses only 3.5% of the cpu at max.
Coule anyone please explain to me if there is a way to overcome this problem. did anyone else have the same problem?
Thanks in advance.
Ivar Kjelberg
Ivar Kjelberg
February 4, 2013 6:06am UTC in response to Deepu Kumar
Re: Comsol 4.3a Memory problem -- not using enough RAM
Check the earlier threads, some solvers cannot use multiprocessing, and several operations are not paralellised, or cannot easily be made so. By default COMSOL will choose at much RAM required and available, and use at least half of all your processors
Deepu Kumar
Deepu Kumar
February 4, 2013 2:51pm UTC in response to Ivar Kjelberg
So in order to use multiple processors, I checked the options of Comsol and changed the number of processors from 1 to the value I have and it seems like it can use many processors. Nevertheless, for the meshing, it still uses around 700MB maximum. At the bottom it always stays
Working set: around 670MB | virtual 780MB.
After changing the number of processors, the cpu %age went up but after 5 minuts the cpu usage stays between 2.5% to 3% and of course it takes forever to mesh. My first trial of meshing is still not done.
Any help would be greatly appreciated.
Thanks Mr. Ivar Kjelberg for your quick response!
Rules and guidelines
