"Failed to compute elastoplastic strain variables" Help Please
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   9 Replies   Last post: October 1, 2013 4:58pm UTC
Rohit Khattar
Rohit Khattar
February 4, 2013 11:55am UTC
I am an absolute beginner at COMSOL Multiphysics and I am trying to model the effect of the movement of soil on a steel pipeline buried in it. I have attached the model file with this post. I am trying to use the Soil Plasticity Criterion but as the tutorial describes, It needs to be given Initial values. So following the built in tutorial, I have included two studies, one for calculating the initial stresses and the other one for calculating the actual stresses on the pipeline.
I would be really grateful if someone could take a look and point out the mistake in my method.
Thanks in advance.
- Rohit
Henrik Sönnerlind
Henrik Sönnerlind
COMSOL Employee
Sweden
Moderator
February 4, 2013 12:14pm UTC in response to Rohit Khattar
Re: "Failed to compute elastoplastic strain variables" Help Please
Knowledgebase entry 1150 discusses this error message.
www.comsol.com/support/knowledgebase/1150/
Henrik
Rohit Khattar
Rohit Khattar
February 4, 2013 2:34pm UTC in response to Henrik Sönnerlind
Thanks for the prompt Reply.
I had come across it before posting the question. I tried the solution suggested but I am still stuck at the same issue.
Suresh  Seetharam
Suresh Seetharam
April 14, 2013 10:21am UTC in response to Rohit Khattar
I had similar problems for the reasons indicated in the knowledgebase, but could overcome because of nature of my problem. I do not have geomechanics module to dissect.
May be you have solved your problem by now, if not, what is important is when you calculate initial stresses for a given domain as your first step that you check if the calculated stresses (if possible, visually from your plots) everywhere in your elastop-plastic domain are below the initial yield stress (this you can obtain from your yield function). If not, you will continue to have the problem. For example, I had certain corners of my domain where von mises stresses were way too high because of a boundary condition and relaxing the geometry a bit helped reduce stresses in such zones. In some cases, introducing an adjacent linear elastic material (which I had ignored to reduce model complexity) solved the problem.
Suresh
Chaney Long
Chaney Long
July 22, 2013 2:17am UTC in response to Rohit Khattar
Have you solved this problem? Can you talk a little bit about it?
Fabio Greco
Fabio Greco
August 23, 2013 1:23pm UTC in response to Suresh Seetharam
Dear Suresh,
I got this problem and I found your reply very interesting. But what I don't understand is what you mean for initial stresses from the first step, that you mentioned. For example, if apply a load on a domain not previously stresses (so initial stresses are 0 at t=0, in a time dependent study e.g.), and the load will lead to plastic deformation.
Since the initial yield stress is the stress level where plastic deformation starts, why the stresses (von Mises) should be below this level? In that case, plasticity will never occur...and it's not possible...
Can you give me an explanation?
Thank you in advance!
\Fabio
Suresh  Seetharam
Suresh Seetharam
August 23, 2013 4:43pm UTC in response to Fabio Greco
Instead of applying the load at once, can you try to ramp it up gradually using a parametric continuation study (or time dependent) and see if it solves.
Suresh
Kimia Mortezaei
Kimia Mortezaei
October 1, 2013 4:30pm UTC in response to Suresh Seetharam
I have this problem, too. when I remove the initial stress this error would be disappeared but once I add it even if the amount is small I have this problem. How can I be sure that the initial stress is less than the yield stress?
Fabio Greco
Fabio Greco
October 1, 2013 4:40pm UTC in response to Kimia Mortezaei
I would say, check the results without using plasticity and compare them with the values of the initial stress...
If you are just using random values of initial stresses (if you are doing some test etc.) you can insert in the matrix of initial stress a reduced value of the yield stress (in Comsol this value is called "Initial yield stress", because of hardening), for instance if your yield stress is 60MPa, try using 6MPa
I hope this helps
Regards
Kimia Mortezaei
Kimia Mortezaei
October 1, 2013 4:58pm UTC in response to Fabio Greco
Thanks for your prompt answer. I tried that but still I have the same problem. as long as there is an initial stress even very small like 1pa there is this error. is there any other things that may causes this error?
Rules and guidelines
