Filter by Topic
Release
Popular Topics
- List all discussions
Stresses built up in a rotating disk
February 21, 2013 11:28am UTC
I am trying to analyze the stresses built up in in rotating disk. This disk is not subjected to any external loading. Only forces applied is centrifugal forces due to rotation.
When I try to model the problem using Structural Mechanics>Solid Mechanics (solid) from COMSOL 4.2 it allows me to enter a linear velocity as a Prescribed Velocity. But I cant enter the rotational or angular speed.
Can I implement this problem in COMSOL using this Prescribed Velocity functionality?or Is there any other way to analyze the stresses in this rotating disk.?
Thank You Very Much.
Shehan
February 21, 2013 5:04pm UTC in response to Shehan Haputhanthri
Re: Stresses built up in a rotating disk
Hi Shehan,
The most efficient way to calculate the stresses due to a steady-state centrifugal load is through a body load = density x omega^2 x radius. You don’t need to prescribe velocity in that case.
Nagi Elabbasi
Veryst Engineering
February 22, 2013 2:54am UTC in response to Nagi Elabbasi
Thanks Nagi for your quick reply. I did the simulation that way and got the results.
I applied the body load in the r direction (In cylindrical coordinate system). What I am not sure here is whether I should applied the loads in all three direction.
Thanks.
February 25, 2013 2:13am UTC in response to Shehan Haputhanthri
If you apply the load in a cylindrical coordinate system aligned with the axis of rotation then you only need to apply a force in the radial direction (as you did).
Rules and guidelines
