3-D Modelling , Filling an open gap
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   3 Replies   Last post: March 18, 2013 8:38pm UTC
Victor Soares
Victor Soares
March 14, 2013 3:28pm UTC
Good Afternoon,
I'm building a damper that has a hollow casing and a rubber-ish inside. This rubber is applied inside the case trough a direct injection.
I'd like to know if I can model the casing ( using Material 1 ) then fill the gap of the case with another material ( Material 2 ).
Ivar Kjelberg
Ivar Kjelberg
March 14, 2013 6:37pm UTC in response to Victor Soares
Re: 3-D Modelling , Filling an open gap
for me it remindsme of eiher a two fluid FSSI interaction or a level set suronded by fluid, but you need some combination of ALE therein, the way I see it, and currently I have problems mixing ALE and level set capilary forces correctly. Something I'm missing to get it right ;)
In anycase forget v4.0 use the latest
Jorden Joe
Jorden Joe
March 17, 2013 7:36pm UTC in response to Ivar Kjelberg
Hi Ivar,
I want in 3D geometry of open-topped, rectangular prism of 1.6 m length, 0.4 m in width and 0.4 m in height. The wall
thickness is 1 mm. The container was filled with water to a depth of 0.3 m.My physics is FSI. I cann't select the container wall when i want to defining its Linear elastic material section.
could you help me!
Jorden
Ivar Kjelberg
Ivar Kjelberg
March 18, 2013 8:38pm UTC in response to Jorden Joe
which version are you using ?
in FSI you need to define the domains fluid and solid by appropriate Domain nodes in the physics node and have both fluid and solid domains defined for the main FSI node
Bt without a model I cannot tell much more ;)
Rules and guidelines
