Electrostatics using deformed result of solid mechanics
Topics: 4.1
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   4 Replies   Last post: April 5, 2013 7:12pm UTC
Tom Long
Tom Long
April 3, 2013 4:38pm UTC
I am new to COMSOL, using version 4.1 to simulate a flexible capacitor. The goal is to have the geometry deformed using a Solid Mechanics simulation (which I have done) then simulate the behaviour of the capacitor in Electrostatics.
I can't work out how to combine the two steps sequentially. Should they be separate Study Steps? If so, how do I pass the deformed mesh from one step to the next?
Thanks for your help!
Sergei Yushanov
Sergei Yushanov
Certified Consultant
AltaSim Technologies, LLC
April 3, 2013 5:20pm UTC in response to Tom Long
Re: Electrostatics using deformed result of solid mechanics
Tom,
You need to add ALE interface to model electromechanical coupling. There is example in the Comsol model library for electromagnetic and structural coupling:
www.comsol.com/showroom/gallery/4461/
Sergei
Ivar Kjelberg
Ivar Kjelberg
April 3, 2013 5:23pm UTC in response to Tom Long
if you combine ALE + Solid+ ES you can get a combined pyiscs to solve together (there should be some examples in the model library, used to be though)
another way is to run solid (on the solid part), save the defomed geoemtry aa a new mesh and solve with ES, but you need to be sure you have the "air part" there so ES can solve. Then you solve one and thereafter the second, stating that you deform your physics in "solid" and the ES gives you independently the capacity for the deformed solid
Tom Long
Tom Long
April 5, 2013 4:03pm UTC in response to Ivar Kjelberg
Ivar, Sergei,
Thanks for pointing me in the right direction. I have made a successful combined model using ALE+Solid+ES.
Unfortunately, it only solves for small deformations - if I increase the deformation then COMSOL crashes when trying to solve. Do you know what can cause this or how I can avoid it?
Ivar Kjelberg
Ivar Kjelberg
April 5, 2013 7:12pm UTC in response to Tom Long
it could be that you need to turn on the remeshing feature for the ALE, and if your solid deformes greatlely, then the non linear geoemtry sovler could be useful to turn on (solver node for Solid). But it could be other things too (mesh density, overlapping or topology change ...
oops not sure remeshing existing back in 4.1, definitively it is there now in 4.3a
Rules and guidelines
