electric field and potential distribution
Topics: 4.3, AC/DC Module
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   5 Replies   Last post: May 8, 2013 2:09pm UTC
N Murugan
N Murugan
May 7, 2013 9:23am UTC
I have been working on a 3D (AC/DC) model of a insulator, and I am trying to verify the uniform potential and field distribution along the insulator surface.
I apply 33Kv voltage at HV end. I got result, in this result potential along the insulator surface is uniform distribution, i want field also uniform distribution along the surface.
Attachments:   field.jpg   potential.jpg
Edgar J. Kaiser
Edgar J. Kaiser
Certified Consultant
emPhys Physical Technology
May 7, 2013 9:34am UTC in response to N Murugan
Re: electric field and potential distribution
the field is the gradient of the potential. So your request is not physical. A uniform potential gives zero field. A linear potential distribution gives a uniform field.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
N Murugan
N Murugan
May 7, 2013 4:57pm UTC in response to Edgar J. Kaiser
Thank u sir
I apply 33Kv voltage at HV end. I got result, in this result potential along the insulator surface is linear distribution, but not uniform field distribution along the surface and also field at HV (33KV) terminal as same as ground terminal, why sir ?
i attach my model image.
Edgar J. Kaiser
Edgar J. Kaiser
May 7, 2013 7:08pm UTC in response to N Murugan
I would expect a higher field close to the terminals and the geometry is the same on both ends.
Edgar J. Kaiser
www.emphys.com
N Murugan
N Murugan
May 8, 2013 1:02pm UTC in response to Edgar J. Kaiser
In HV end : field is high bcoz 33Kv applied, but same field will occur in ground end (zero potential), why sir?
Attachments:   elelctric field plot.jpg
Edgar J. Kaiser
Edgar J. Kaiser
May 8, 2013 2:09pm UTC in response to N Murugan
Sure, your geometry is symmetric. It doesn't matter where HV and ground are connected.
But looking at your pictures, I think you are making a very basic mistake. You don't have an air volume around your device. So you confine the model into the interior of the device. That is probably not what you want.
Another hint: The device has axial symmetry. You can save tremendous memory and computing time by setting up this in 2Daxial geometry. And the precision of the results can be much better.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Rules and guidelines
