3D optical waveguide error
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   6 Replies   Last post: July 9, 2013 7:32am UTC
Mark Daly
Mark Daly
June 10, 2013 6:53am UTC
Hello everyone,
What I'm trying to do is basically simulate an optical fiber in 3D. I thought it would be a simple task but I'm running into an error.
I created an optical fibre with an air cladding. The fiber is very thin (.5 um radius).
I thought all I would have to do was create an input port and and exit port, perform a boundary mode analysis on both ports and then add the frequency domain study.
When I do this i get the following error:
Undefined value found.
- Detail: NaN or Inf found when solving linear system using SOR.
Does anyone know what I am doing wrong? Any input would be greatly appreciated.
Thank you,
Mark
Abutaleb Haidary
Abutaleb Haidary
June 10, 2013 4:47pm UTC in response to Mark Daly
Re: 3D optical waveguide error
Which kind of excitation port you are using for this 3D model?
Mark Daly
Mark Daly
June 11, 2013 5:43am UTC in response to Abutaleb Haidary
I'm using a numeric port. Should I try a user defined port?
Mark Daly
Mark Daly
June 18, 2013 4:30am UTC in response to Mark Daly
Is there any way to solve for a field in a 2D model and then import that solution into the 3D model for the boundary mode analysis and then see how it propagates in the 3D model?
Mark Daly
Mark Daly
June 19, 2013 9:28am UTC in response to Mark Daly
One last question. I hope someone will answer :)
In the 2D model of a circular optical fiber you can see the modes present. If I make a 3D fiber and only perform a single boundary mode analysis on one input should I be able re recreate the 2D models results? I've tried this with no luck thus far.
Mark
Mark Daly
Mark Daly
July 9, 2013 4:52am UTC in response to Mark Daly
Hello again,
I've updated to 4.3b and I'm trying a similar model. I think what I have should work but I can't get it to compile.
Could someone take a look at my model and see if there are any obvious mistakes? The solver gets to about 70% but then it stalls for a long time. I think my mesh is correct.
Any advice is welcome!
Mark.
Attachments:   Optical Fibre_2_rev.mph
Stefano Firpi
Stefano Firpi
July 9, 2013 7:32am UTC in response to Mark Daly
Here is my two cents.
Don't have the RF module so I can't take a look at your model but if the solver stalls, it means there are convergence issues; as the model is quite simple (or it should be) this means something is wrong with the physics.
Rules and guidelines
