Discussion Forum
Interpolation function of dependent variables
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   3 Replies   Last post: July 23, 2010 4:00pm UTC
Shao-Ling Wu
Shao-Ling Wu
March 12, 2010 2:40pm UTC
I have been trying to solve a problem which requires interpolation functions or look-up tables. I know we can import data files by adding functions into COMSOL. I have tried that, and it worked. The interpolation functions were dependent on spatial coordinates (r and z).
Now I need to solve a similar problem, but in which case the interpolation functions are dependent on "dependent variables".
For example, I am solving concentration (c) and potential (V) in an electrochemical system. I have a parameter "f" which is a function of concentration and potential, i.e., f=f(c,V). This parameter is used in one of my boundary conditions. I cannot find an explicit expression for "f" in terms of c and V. However, I can make a look-up table for "f".
So this is what I did.
I defined "f" in Options --> Functions, and it is interpolated from an external .txt file. In the text file, the two variables are c and V.
The results do not look correct.
Can COMSOL support an interpolation function dependent on dependent variables?
or Is there any other method to solve it?
Thank you very much!
Jie Xiang
Jie Xiang
July 22, 2010 3:22pm UTC in response to Shao-Ling Wu
Re: Interpolation function of dependent variables
Hi, Shao-Ling,
I also tried to use interpolation function and met a problem. Can you give me some suggestion?
I am trying to interpolate spatial-varying material data. The interpolation functions were dependent on spatial coordinates (r)
In Comsol Multiphysics user guide, the spatial arguments are x,y,z.
My question is:
How can we use r (r=sqrt(x^2+y^2)) as the spatial arguments?
Ivar Kjelberg
Ivar Kjelberg
Moderator
July 22, 2010 8:35pm UTC in response to Jie Xiang
define a global variable r = sqrt(x^2+y^2) and use "r" thereafter, check the doc for global variables
Jie Xiang
Jie Xiang
July 23, 2010 4:00pm UTC in response to Ivar Kjelberg
Hi, Ivar,
Thanks very much for your reply. I followed your sugestion,define a global variable r = sqrt(x^2+y^2), and also define a global interpolation ep_r(r). However, it still did not work. It seems that Comsol has not recognized this variable r in the interpolation ep_r(r). Maybe I did not understand your comments " use "r" thereafter ".
Can you explain more about this?
The attached mph file is my model.
Thanks in advance
Rules and guidelines
