Heat transfer in three blocks
Topics: 4.3b
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   1 Reply   Last post: June 19, 2013 4:37pm UTC
Alan Bergman
Alan Bergman
June 19, 2013 8:57am UTC
Hello.
I have side-by-side three blocks of three difference materials. I want to explore the heat transfer in these blocks when applying a temperature on the surface between the first and second walls. I encounter the following problem.
Heat transfers through the first and second blocks, but it doesn't penetrate into the third block, because it's material is different. When I make the material of the first and third blocks the same, it works fine.
What can I do in this case?
Thanks is advance.
Nagi Elabbasi
Nagi Elabbasi
Certified Consultant
Veryst Engineering
June 19, 2013 4:37pm UTC in response to Alan Bergman
Re: Heat transfer in three blocks
Dear Alan,
That’s strange. Maybe your material properties are such that it takes a very long time for the temperature to penetrate the material and you are not solving for a sufficiently long time duration (assuming you are performing a time domain analysis).
Nagi Elabbasi
Veryst Engineering
Rules and guidelines
