Problem with Large domain
Topics: 4.3b, RF Module
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   2 Replies   Last post: February 12, 2015 2:40pm UTC
Kapil Debnath
Kapil Debnath
June 27, 2013 11:36am UTC
I am simulating propagation through a simple waveguide in 3D.
The simulation is working perfectly as long as the length of the waveguide is below 10um. When I increase the device length to 10um, the simulation continues and reaches the convergence, however at the final step an error message appears. as below.
Failed to find a solution.
Very ill-conditioned preconditioner.
The relative residual is more than 1000 times larger than the relative tolerance.
Returned solution is not converged.
I have attached the file. I would appreciate any suggestions.
Thank you
Kapil
Attachments:   Ribwaveguide10um.mph
Mohammed Thameemul Ansari
February 9, 2015 2:40am UTC in response to Kapil Debnath
Re: Problem with Large domain
Hello sir
The same error am facing now. Did you fix the problem?
May i know what is the solution for the problem?
Walter Frei
Walter Frei
COMSOL Employee
USA
Moderator
February 12, 2015 2:40pm UTC in response to Kapil Debnath
Dear Kapil,
You may want to check the geometric scales here. You would want units of microns, not meters.
Reply  |  Reply with Quote  |  Report Abuse
Rules and guidelines
