Filter by Topic
Most Popular
All Topics
- List all discussions
Phase difference in current-carrying conductors
March 19, 2010 12:12pm UTC
Hi.
I am building a model where 1kA, 50Hz three-phase current is passing trough a 80mm steel wall in (three..) copper conductors (r=12.5mm). The copper conductors are isolated from the steel wall with isolators (r=35mm).
The model will provide an estimate of resistive losses in the steel wall due to induced currents.
Creating and solving the model without taking the 120deg phase shifts of the currents into consideration seems easy enough.
But how do i model the 120deg phase shift between the currents?
I am not interested in the time-varying magnetic fields, only the total resistive losses in the steel wall.
Thanks in advance.
- tore
March 19, 2010 1:39pm UTC in response to Tore Berge
Re: Phase difference in current-carrying conductors
quick reply with first thoughts, but one need to check carefully in the doc, if you are in time domain add a phase term to your sinus, but I would expect you to work in the hamonic mode, then I woud use the phasor for the three currents. I believe there is something like that on the forum, try a search. or was it one of the example
Will have a look again tonight, just too busy right now ;)
Lykke til
March 19, 2010 10:33pm UTC in response to Ivar Kjelberg
Hi again
In fact, having had a second look, I assume you are in ACDC mode Time harmonic current mode, then your current flow boundary condition has a J0 [A/m^2] that chould be expressed as Jin[A/m^2]*e^(i*phase) here the imaginary part is the phase, 0, 2/3*pi, 4/3*pi for you, just check thatyou have the correct frequency too, the default is not always the one wanted.
It's explained in the doc, try the ACDCUG.PDF and search for "phase" and "phasor"
I did not find back the example I was thinking off, it could have been one from one of the COMSOL courses I have followed
March 23, 2010 9:15am UTC in response to Ivar Kjelberg
Hello Ivar.
Thank you for your reply.
As you say, I work in ACDC time-harmonic mode - 3D.
I have entered the following expressions for my three currents as the "Inward current flow" - Jn - boundary condition.
1000*exp(j*0*pi)
1000*exp(j*2/3*pi)
1000*exp(j*4/3*pi)
Still finding this somewhat cryptical, I would like to verify the behaviour of the currents in an animation.
I have found the "explanation" on how to animate phasors in the documentation, but I have difficulties understanding it. All my attempts result in a animation where nothing is changing.
Can you explain what I need to do?
- tore
March 23, 2010 12:26pm UTC in response to Tore Berge
this says me something, we have treated that earler, try a search on the forum, sucn as animation and phasor or phase
I'm stuck in a meeting for some hours
Lykke til
Rules and guidelines
