Non-selected node affects end-results
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   4 Replies   Last post: October 29, 2013 11:45am UTC
Machiel Kolstein
Machiel Kolstein
October 25, 2013 4:53pm UTC
I have various physics nodes in one single project. (Both are Transport of Diluted Species nodes.) One of them works with a variable "n" and another "h". I also have a Study, with a Step which is Time Dependent. Here, in "Physics and Variables Selection", I only select one of the two nodes (let's say, with output "n"). However, when I plot out the results (i.e variable "n"), these seem to be influenced by both nodes. When I only plot "h", I get 0, as it should be.
When I disable the second node (the one with "h"), and redo the study, then the result, plotting "n" is as expected.
In other words: the "n" result depends on whether or not the "h"-node is enabled, even though the "h-node" is not included in the time-dependent Study Step (nor in any other Study Step)! How is this possible?
Why does a node influence my result, even when the node it is not selected in the Study section?
Machiel
P.D. (I have COMSOL multiphysics 4.3a)
Machiel Kolstein
Machiel Kolstein
October 28, 2013 5:22pm UTC in response to Machiel Kolstein
Re: Non-selected node affects end-results
Hi again,
After investigating some more, I found that this problem only occurs, when the "non-selected" node has a variable "h". Whenever I change the name of the variable, the problem is solved.
Actually, when I switch on the node, with variable "h", the program gets stuck. However, changing the variable name, the program gives a good result.
From this I deduced that "h" was some kind of proteced variable (Planck's constant). Fair enough. However, when I use "c" instead of "h", the problem does not occur.
In any case, shouldn't COMSOL give me a warning when I accidently use a constant as a variable name?
Machiel
Jeff Hiller
Jeff Hiller
COMSOL Employee
USA
Moderator
October 28, 2013 6:55pm UTC in response to Machiel Kolstein
h is the element size, per Reference Manual, version 4.3b, page 244.
h_const is the Planck constant, per Reference Manual, version 4.3b, page 257.
c_const is the speed of light, per Reference Manual, version 4.3b, page 257.
c is the default name for concentration if you have a mass transfer equation in your file, per Reference Manual, version 4.3b, page 714.
Machiel Kolstein
Machiel Kolstein
October 29, 2013 10:27am UTC in response to Jeff Hiller
Thank you very much for your reply and confirm this issue. I don't have version 4.3b, but 4.3a, but in the User Guide, on pages 153 and 166, I found the information as you stated. I use two Transport of Diluted Species nodes, so I can't just stick to the default "c". Anyway, I will be more careful in selecting variable names in future.
Still, I think it might not be a bad idea if COMSOL would provide some warning when a user tries to use certain reserved variables (like h or t or x) in the inappropiate place.
Machiel
Jeff Hiller
Jeff Hiller
COMSOL Employee
USA
Moderator
October 29, 2013 11:45am UTC in response to Machiel Kolstein
Hi Machiel,
Thank you for your feedback.
Rules and guidelines
