2D Fluid forcing a turbine to rotate
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   7 Replies   Last post: February 11, 2014 9:51pm UTC
Chris Mullen
Chris Mullen
February 7, 2014 4:39am UTC
Hi, I'm reading about a lot of people who want a tutorial on how COMSOL works, and I hope this doesn't come across as that. I'm trying to build a turbine that moves due to the force of a fluid pushing on it. I've been going over other models on the website, but they all seem to be mixers or a rotating part that moves the fluid around it. In my case, it's the reverse, that is, it's the fluid that is making the turbine rotate. My question is, what should I be doing to the "Rotating Machinery, Laminar Flow" section that would simulate the fluid pushing against the turbine and making it rotate? Thank you very much for your help!
ChrisM.
Marino Miccio
Marino Miccio
February 10, 2014 11:48am UTC in response to Chris Mullen
Re: 2D Fluid forcing a turbine to rotate
Hi Chris,
if you want to perform an interaction between a solid and a fluid you should use the Fluid-Structure Interaction physics.
It has the equations and features for fluid-structure interaction, solving for the displacements, fluid velocity, and fluid pressure.
Have a good work.
Marino Miccio
Chemical Engineer
marinomiccio.wix.com/home
Chris Mullen
Chris Mullen
February 10, 2014 3:17pm UTC in response to Marino Miccio
Mr Miccio,
Thank you very much for responding to my question. I found this example on comsol.com:
www.comsol.com/model/download/...luid_structure_interaction.pdf
In the pdf file it says, "In the Add physics tree, select Fluid Flow>Fluid-Structure Interaction (fsi)", but the Comsol version I'm using doesn't have that option. Is there another way I can generate the same results?
Thank you,
ChrisM.
Marino Miccio
Marino Miccio
February 10, 2014 3:45pm UTC in response to Chris Mullen
I think that this physics is the only solution to take in account the interaction between a solid and a fluid phase. It's strange that your Comsol doesn't support it. Which version do you have?
Marino Miccio
Chemical Engineer
Chris Mullen
Chris Mullen
February 10, 2014 11:31pm UTC in response to Marino Miccio
I'm using Multiphysics version 4.3b. I went through again just in case I missed something, but Fluid-Structure Interaction physics is not there. My version shows:
Fluid Flow
- Single-Phase Flow
- Thin-Film Flow
- Multiphase Flow
- Porous Media and Subsurface Flow
- Non-Isothermal Flow
- High Mach Number Flow
- Particle Tracing for Fluid Flow
I went through each category and looked for the Fluid-Structure Interaction option, but it wasn't there. Is this an additional Module that must be purchased?
Thanks again,
ChrisM.
Jeff Hiller
Jeff Hiller
COMSOL Employee
USA
Moderator
February 11, 2014 1:25pm UTC in response to Chris Mullen
Hello Chris,
The FSI capability is in the Structural Mechanics Module and in the MEMS Module (see www.comsol.com/products/specif...es%20and%20Study%20Types_55197).
You can check which modules your license includes by going to File>Licensed and Used Products (in version 4.4) or Options>Licenses (in versions 4.0-4.3b)
Reply  |  Reply with Quote  |  Report Abuse
Chris Mullen
Chris Mullen
February 11, 2014 9:00pm UTC in response to Jeff Hiller
Hi Jeff,
Thanks for your response. I checked the license, and it looks like we don't have those two modules. It's a university license, so I think I'm stuck with what we have, unfortunately.
Thanks again for your help,
ChrisM.
Jim Ring
Jim Ring
February 11, 2014 9:51pm UTC in response to Chris Mullen
I am working on a similar problem and am taking a different approach. From what I read you are looking for the torque that the turbine put out not the internal stresses of the turbine. I am attempting to use rotating machinery fluid flow and specifying the fluid flow rate and the rotation rate and asking for the torque of the rotating element as an output.
I would like to be able to do as described above and also solve for stress in rotor, but do not see a path to do this yet.
Rules and guidelines
