3D => RF model => Electromagnetics waves how do I express the "surface charge density "?
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   4 Replies   Last post: September 18, 2010 12:23am UTC
You Zhe Ho
You Zhe Ho
September 15, 2010 4:15pm UTC
Dear all
I'm a beginner at COMSOL 3.5a
IN 3D => RF model => Electromagnetics waves
how do I express "surface charge density "?
I know the expression of the surface charge density magnitude is "normJs_rfw"?
THANH YOU ,
BEST REGARDS
DANNY
Robert Koslover
Robert Koslover
September 15, 2010 8:37pm UTC in response to You Zhe Ho
Re: 3D => RF model => Electromagnetics waves how do I express the "surface charge density "?
Short answer: Well, for a *conducting* surface in empty space, the surface charge density can be expressed as the norm of the electric field divided by epsilon_0. I.e., surface charge density [coulombs/m^2] = normE_rfw/epsilon0_rfw. This follows simply from Gauss' law of electrostatics (which is valid in the RF case as well). (Remember: "Del dot E = rho / epsilon_not" ) (Just consider a thin pillbox around the surface and the integral form of Gauss' law.)
More complicated example: For an interface between two dielectrics, you''ll probably want to begin with D instead of E, and derive an expression that is similar, but based on the more general expression, "Del dot D = rho free" and also recognize the existence of electric displacement fields on *both* sides of the interface. For example, suppose your interface is the x-y plane, so that the normal points along the z axis. Then the free surface charge density on the interface should be given by Dz_rfw (on the right side) - Dz_rfw (on the left side). Note the discontinuity of the field, which I suppose may complicate this. Regardless, I suppose you could find the surface charge at a dielectric interface by interrogating your computed D-field results near the boundary on both sides, in post processing inspection. And then, of course, there is the "bound" charge density to consider also in the case of dielectrics. You might want to re-check the exact EM definitions, when working with dielectrics. Good luck.
Robert Koslover
Robert Koslover
September 15, 2010 8:40pm UTC in response to You Zhe Ho
Correction for the conducting surface case: Surface charge density = epsilon0_rfw*normE_rfw.
Sorry about that.
You Zhe Ho
You Zhe Ho
September 17, 2010 5:23am UTC in response to Robert Koslover
but "Surface charge density = epsilon0_rfw*normE_rfw" ,the normE_rfw means a scalar ,ie, normE_rfw is the magnitude of the electric field not a vector.
if the normE_rfw is normal to any surface ,then it could be right.
Robert Koslover
Robert Koslover
September 18, 2010 12:23am UTC in response to You Zhe Ho
Well, I'm not 100% sure what you mean here, but you sound confused about "norm" vs "normal." You are correct that normE_rfw is a scalar. It is the magnitude (or "norm") of E. Now, for a perfectly conducting surface, E will also be perpendicular to that surface. And any vector perpendicular to a surface is said to be "normal" to that surface. So the vector E will be normal to the conducting surface.
And finally, in the case of a dielectric junction, although E (and likewise D) may not be normal to the surface, the normal (aka, perpendicular to the surface component) of E (or D) is still what you would want to use when extracting surface charge densities.
Does that help?
Rules and guidelines
