Thin Thermally Resistive Layer on top of Boundary Heat Source
Topics: 4.2a, Heat Transfer
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   2 Replies   Last post: June 28, 2013 8:18pm UTC
Bastian Schmitt
Bastian Schmitt
June 3, 2013 10:17am UTC
Hello everybody,
I want to simulate a flat mikroheater on top of a foil that is covered by a liquid. Since the foil has a thickness of about 100µm and the liquid covering the heater has a height of 1mm, the heater's height of about 0,5µm is almost negligible. Additionally the heater is covered with a thin passivation layer with 5µm thickness.
To simulate the temperature increase of the heater I wanted to use "Boundary Heat Source" with a defined "Total boundary power". On top of it I wanted to use a "Thin thermally resistive Layer", but I did not find out how to defne two layers on top of each other.
Is there any possibility to do so?
Many thanks in advance
Bastian
Bastian Schmitt
Bastian Schmitt
June 28, 2013 9:58am UTC in response to Bastian Schmitt
Re: Thin Thermally Resistive Layer on top of Boundary Heat Source
probably it is not possible, see: "can comsol support multilayer shell?"
www.comsol.com/community/forums/general/thread/28316/
Best regards
Bastian
Nagi Elabbasi
Nagi Elabbasi
Certified Consultant
Veryst Engineering
June 28, 2013 8:18pm UTC in response to Bastian Schmitt
Hi Bastian,
This issue is different from multilayered shells. A boundary heat source is not a “layer”. It is strictly on the boundary. A thin thermally resistive layer has to be internal to the domain. If I understand your problem correctly you should create a line/surface offset from the boundary and apply the thermally resistive layer there.
Nagi Elabbasi
Veryst Engineering
Rules and guidelines
