Discussion Forum
Multiple input ports in RF problems
Topics: RF, Microwave
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   3 Replies   Last post: June 8, 2010 4:13pm UTC
Roberto Olmi
Roberto Olmi
September 23, 2009 8:36am UTC
Hello to everyone.
The RF module Users Guide, at page 72, says (Note at the top of the page) that it is possible to have more than an excited inport, with the drawback that S-parameters are not correctly computed.
On the contrary, COMSOL seems to not allow this: I need to excite a microwave cavity with two waveguides at the same time, but the program does not allow me to put a waveguide excitation on both ports.
Any suggestion?
Thnaks,
Roberto
Robert Koslover
Robert Koslover
October 3, 2009 5:26pm UTC in response to Roberto Olmi
Re: Multiple input ports in RF problems
Well, it works for me. I just designed a custom waveguide structure with 3 excited input ports and 4 output ports.
Any chance you are failing to specify unique port numbers for each port? The default port number for each port is 1. If this is your problem, then number your ports 1, 2, 3, etc, and it should work.
lukas Alberts
lukas Alberts
May 6, 2010 2:17pm UTC in response to Robert Koslover
for me it says definitely
Error: 5025
More than one port used as input.
- Port number: 5,2
- Boundaries: 29,1
- Application mode: In-Plane TE Waves (rfwe)
2 input ports with differen portnumbers.. 2 and 5..
is the way to add a rfwe physics module?
but then one has to repeat the subdomain definitions..
thanks
lukas
Felix Vega
Felix Vega
June 8, 2010 4:13pm UTC in response to lukas Alberts
You should try to do superposition
Rules and guidelines
