File access using Java API in batch mode
I am currently experimenting with Java API for using COMSOL. I have discovered that I have a problem with external files when using comsolbatch.
The following code (see bottom of post) is for a simple model which opens a basic geometry from the file "SimpleSphere.mphbin" which is located in my model working directory D:\WK. If I compile this to a .class file and open this in the COMSOL interface the model works as expected. However if I open this in batch mode I get the error message below. However if I copy the the file "SimpleSphere.mphbin" to the file location of comsolbatch.exe then the .class file runs with no errors in batch mode.
I believe that COMSOL should be able to locate the file, since I have specified the model working directory with the line model.modelPath("D:\WK");
I also believe that there should be no problem with COMSOL security settings since I have unchecked "Enforce security restrictions".
Please could somebody knowlegable about this offer their opinion. You can assume that I don't know much about java programming.
Kind regards
< error message >
COMSOL 5.1.0.136 progress output file
Mon Oct 22 17:02:40 KST 2018 COMSOL 5.1 (Build: 136) starting in batch mode Running: D:\WK\Test_01.class
/******************/ /*****Error********/ /******************/ access denied ("java.io.FilePermission" "D:\WK\SimpleSphere.mphbin" "read") Saving model: D:\WK\Test_01_out_Model.mph Save time: 1 s. Total time: 4 s.
< end error message >
{ /* * Test_01.java */
import com.comsol.model.*; import com.comsol.model.util.*;
public static Model run() { Model model = ModelUtil.create("Model");
model.modelPath("D:\\WK");
model.label("Test_01.mph");
model.comments("Untitled\n\n");
model.modelNode().create("comp1");
model.file().clear();
model.geom().create("geom1", 3);
model.mesh().create("mesh1", "geom1");
model.geom("geom1").create("imp1", "Import");
model.geom("geom1").feature("imp1").set("filename", "SimpleSphere.mphbin");
model.geom("geom1").feature("imp1").set("type", "native");
model.geom("geom1").feature("imp1").importData();
model.mesh("mesh1").run();
return model;
public static void main(String[] args) { run(); }
0 Replies Last Post Oct 22, 2018, 4:33 a.m. EDT
Hello Liam Kelly
