[solved] damped oscillations in a piezoelectric cantilever
4 Replies Last Post Oct 14, 2010, 12:32 p.m. EDT
Posted: 2 decades ago Oct 8, 2010, 6:44 a.m. EDT
I can't look at your model because I dont have COMSOL on this computer, but wouldnt the damping effect be due to the fact that your cantilever is made of two different materials, each of which will respond differently to the oscillation?
Posted: 2 decades ago Oct 12, 2010, 11:15 a.m. EDT
Posted: 2 decades ago Oct 13, 2010, 1:44 a.m. EDT
depending on how you connect up electrically your PZT you could have damping, there might be some "numerical damping" I believe for stability reasons, check the doc
Hi depending on how you connect up electrically your PZT you could have damping, there might be some "numerical damping" I believe for stability reasons, check the doc -- Good luck Ivar
Posted: 2 decades ago Oct 14, 2010, 12:32 p.m. EDT
Good evening,
I found the problem. It was due to a too large time stepping in the transient analysis settings.
With 1/100 of the period as time step everything works fine.
Good evening, I found the problem. It was due to a too large time stepping in the transient analysis settings. With 1/100 of the period as time step everything works fine.
