Rotating geometry in 3D plot
Posted Jan 3, 2014, 3:33 a.m. EST Version 4.2 0 Replies
First, I design a rotating disc simulation in 3D space. I select the model physics by 'Solid mechanics'.
In this physics, I insert some values to 'Velocity field' of 'initial Values'.
x = -y*(2*pi)*(RPM/60), y = x*(2*pi)*(RPM/60), z=0.
I think, this values work as 'angular velocity of rotation motion'. Is it correct?
Second, I have to 3D plot of simulation results. I select study step as 'Time dependent'.
And I choice a 3D plot --> volume --> deformation.
I want to 'see' the simulation : geometry of disc 'really' rotating at each time interval.
For example, If the disc's RPM equals to 15[rpm]=0.25Hz and time range equals to range(0,0.25,1), then
disc will be rotate 90 degree at each time point.
(0deg/0sec, 90deg/0.25sec, 180deg/0.5sec, 270deg/0.75sec, 360deg/1sec)
I want to 'real' rotating simulation in 3D plot. I hope the geometry of rotating disc is 'visually' rotation.
I use a COMSOL 4.2ver.
Please help me.
Thank you !
Hello H.M. Song
