Batch importing CAD models into COMSOL?
I'm using SIEMENS NX to create the CAD model which will subsenquently be imported into COMSOL for further simulation. Each CAD model is exactlly the same except for one parameter value. So it's a parameter study. My questions are:
  1. Is there a LiveLink between SIEMENS NX and COMSOL?
  2. If not, is there a function in COMSOL that can batch import CAD models and simulate one by one?
  3. If this function does not exist, can this be achieved by some codes?
Thanks in advance.
Zhang Ze
4 Replies Last Post Jan 14, 2019, 3:51 a.m. EST
Posted: 7 years ago Jan 10, 2019, 4:56 a.m. EST
Hi Ze
No, we don't currently have a LiveLink for Siemens NX.
You can export the NX CAD models as a Parasolid files and import them into Comsol using the Comsol GUI.
The CAD file import can be scripted in Comsol so you can loop over CAD files. You can do this using an app or by using LiveLink for Matlab. Note that the license agreement requires you to create a GUI to control the process.
If you define suitable selections in your Comsol model you can make sure that boundary settings are correctle placed on the imported geometry befor solving.
Lars Gregersen
Comsol Denmark
Hi Ze No, we don't currently have a LiveLink for Siemens NX. You can export the NX CAD models as a Parasolid files and import them into Comsol using the Comsol GUI. The CAD file import can be scripted in Comsol so you can loop over CAD files. You can do this using an app or by using LiveLink for Matlab. Note that the license agreement requires you to create a GUI to control the process. If you define suitable selections in your Comsol model you can make sure that boundary settings are correctle placed on the imported geometry befor solving.
Posted: 7 years ago Jan 10, 2019, 5:02 a.m. EST
Hi Ze
Hi Lars,
Thanks for the reply. It's good to know that this can be achieved somehow. I do have the license for Matlab Livelink. Would you please give me a little bit more information on how to import using Matlab Livelink?
Regards, Zhang Ze
>Hi Ze > >No, we don't currently have a LiveLink for Siemens NX. > >You can export the NX CAD models as a Parasolid files and import them into Comsol using the Comsol GUI. > >The CAD file import can be scripted in Comsol so you can loop over CAD files. You can do this using an app or by using LiveLink for Matlab. Note that the license agreement requires you to create a GUI to control the process. > >If you define suitable selections in your Comsol model you can make sure that boundary settings are correctle placed on the imported geometry befor solving. Hi Lars, Thanks for the reply. It's good to know that this can be achieved somehow. I do have the license for Matlab Livelink. Would you please give me a little bit more information on how to import using Matlab Livelink? Regards, Zhang Ze
Posted: 7 years ago Jan 11, 2019, 3:31 a.m. EST
Updated: 7 years ago Jan 11, 2019, 8:32 a.m. EST
Hi Zhang Ze
CAD file import is described to some extent in the Programming Reference Manual and there is also a programming reference chapter in the CAD Import Module User's Guide where you should read about the "Import" feature.
In order to get a useful example I recommend that you set up a model in the Comsol GUI (including selections and physics settings) and save the model as an M-file to learn about the syntax.
The challenge will be how to handle selection so the model is set up correctly. This depends heavily on your geometry and the physics settings you need to have in your model. There is more info about that here: https://www.comsol.com/blogs/automatically-handling-selections-comsol-multiphysics/
Lars Gregersen
Comsol Denmark
Hi Zhang Ze CAD file import is described to some extent in the Programming Reference Manual and there is also a programming reference chapter in the CAD Import Module User's Guide where you should read about the "Import" feature. In order to get a useful example I recommend that you set up a model in the Comsol GUI (including selections and physics settings) and save the model as an M-file to learn about the syntax. The challenge will be how to handle selection so the model is set up correctly. This depends heavily on your geometry and the physics settings you need to have in your model. There is more info about that here: https://www.comsol.com/blogs/automatically-handling-selections-comsol-multiphysics/
Posted: 7 years ago Jan 14, 2019, 3:51 a.m. EST
Hi Zhang Ze
Hi Lars,
Thank you for the reply. I will have a look on the links.
Regards, Zhang Ze
>Hi Zhang Ze > >CAD file import is described to some extent in the Programming Reference Manual and there is also a programming reference chapter in the CAD Import Module User's Guide where you should read about the "Import" feature. > >In order to get a useful example I recommend that you set up a model in the Comsol GUI (including selections and physics settings) and save the model as an M-file to learn about the syntax. > >The challenge will be how to handle selection so the model is set up correctly. This depends heavily on your geometry and the physics settings you need to have in your model. There is more info about that here: >https://www.comsol.com/blogs/automatically-handling-selections-comsol-multiphysics/ Hi Lars, Thank you for the reply. I will have a look on the links. Regards, Zhang Ze
