apply a limiter function for the solution in time-depedent simulation
Posted Nov 13, 2016, 8:57 p.m. EST Parameters, Variables, & Functions, Studies & Solvers Version 5.2 0 Replies
I have such a question. I have a one variable time-dependent problem, let's say the variable is T.
'T' is meaningful when it is below a threshold value, 'Tmax'. When 'T' is larger than that, the
simulation will blow up.
Is it possible to apply a limiter function on 'T' after each time step, such that when
'T' is above 'Tmax', its solution will be forced to be equal to 'Tmax'. This does not sound
like a tricky operation for a normal in-house code, right? Also it does not really matter which
module I am using or whether PDE is used, right?
Thanks in advance,
lailai
Hello sandy
