Apr 5, 2011, 2:08 a.m. EDT
my only advice, start simple: take a box with one inlet and one outlet get it to work, then add a second inlet etc
Start with a few of the model library examples you will learn much quicker to follow them
Apr 15, 2011, 2:15 a.m. EDT
Greeting :)
Thanks for the advice. Its work :)
By the way, could you please explain to me the function of "generating solver sequence"?
As I plan to coupled:
i) Turbulence flow
ii) Transport of diluted species
iii) Heat transfer in solid, fluid, participating media
Your answer is much appreciated :)
Thanks you,
Chong
Greeting :)
i) Turbulence flow
Thanks you,
Chong
Apr 15, 2011, 9:41 a.m. EDT
First be sure you have the latest v4.1 doc as its much better/more complete than the 4.0.
Then right click on the solver nodes to look at the options systematically, and read carefully the related solver doc.
Normally, I always let COMSOL generate a "default solver sequence, once I have added up one or a few of them in the first solver type node level. Then depending on my model, I add segregated solver nodes, separate or re-organise the dependent variables (if I'm not happy, even if Mostly COMSOL is proposing fully valid solutions)
May 3, 2011, 5:19 a.m. EDT
Thanks Ivar for the helpful reply.
With your previous help, now I'm moving on with NOx (Nitric Oxide) simulation in Biomass Combustion.
But currently I'm stuck in which Module to use:
i) Transport of diluted species; or
ii) Reaction engineering?
Can you briefly guide me how to model NOx formation in COMSOL?
Or are there any examples i can refer to?
Million thanks.
Chong
Million thanks.
Chong
May 3, 2011, 5:34 a.m. EDT
Chemical reaction lab is not my speciality so I'm not the best to ask, but there must be someone else out there.
What I can say as transport of diluted species is for me mainly "transport" without reactions TBC, while reaction engineering is to keep the balance of the ongoing chemical reactions.
Remains to study (I do not know and would have to dig deep in there, but do not really have any time just now) if the reaction enginerring physics contain the transport physics too
May 3, 2011, 6:03 a.m. EDT
Noted. thanks :)
Noted. thanks :)
