Flow through the porous material (Brinkman equation study)
Posted Apr 4, 2018, 4:36 a.m. EDT Structural & Acoustics, Fluid & Heat, Studies & Solvers Version 5.3a 0 Replies
Dear friends, i was trying to make a brinkman equation study for the 2D rectangular geometry. I need to identify the pressure drop between the inlet and oulet of the object. The fluid flow through the porous material is the topic of my interest. . Also i applied specific velocity to the inlet and pressure to the outlet.The parameter which is changing is the porousity of the material.In theory, the change in the porousity need to change the values of the pressure. However,in my solution the pressure values stay the same. What can be wrong with solution ? thank you in advance
Hello Dinara Junuskaliyeva
