Heat transfer with phase change in porous Media
Posted Jun 19, 2018, 11:09 a.m. EDT Geomechanics, Heat Transfer & Phase Change, Porous Media Flow 0 Replies
Hello, I've looked at many great discussion about "heat transfer with phase change in porous Media" like the one here: https://www.comsol.com/forum/thread/98481/pcm-as-a-porous-medium?last=2016-01-20T10:45:41Z
It's been mentioned that the phase change phenomenon can be implemented in the heat transfer in porous media interface as described in that blog post: www.comsol.com/blogs/phase-change-cooling-solidification-metal/". However, once I add the Phase Change Node to the domain, it will OVERWRITE on the Porous Medium node, so I am not sure if Porous Medium node still has affect or not. Can someone tell me if both nodes will be has effects even if one overwrites on the other one?
Thank you, Ahmad.
Hello Ahmad Aljabr
