                                7 years ago
                                Feb 13, 2019, 11:07 p.m. EST
                                                    Hi Tygvi,
If it was me I would set up 2 dependent variables: bacteria and chemoattractant. That way I can describe the diffusion of each separately.
Or if their transport mechanism is different, for example if only chemoattractant can be transported by both convection and diffusion, I would set up 2 separate transport of diluted species physics, one discribing bacteria the other chemoattractant.  Good luck
Claire
                            Hi Tygvi,
Claire
                                Trygvi Zachariassen Laksafoss
                                7 years ago
                                Feb 14, 2019, 3:24 a.m. EST
                                                    Hi Claire, thanks alot for the reply. I do have a separate dependant variable describing the change and diffusion of chemoattractant which works correctly. It is only the diffusion of the bacteria that cause issue. From the equation mentioned, the diffusion of cells is dependant on two gradients, the cells and chemoattractant. I have not yet found a way to have two diffusion terms in one equation using the COMSOL interface, but i am looking into using equation based mdoelling which might solve the issue.
Trygvi
Trygvi
                                7 years ago
                                Feb 14, 2019, 10:37 a.m. EST
                        Updated:
                                7 years ago
                                Feb 14, 2019, 1:03 p.m. EST
I presume you could still use the transport in dilute species, only additional step being adding a "reaction" or "species source" term in the domain contribution.  Because the units are consistent, i.e. mol/m3/s.
I do not know your terms well, but for demonstration purposes, let us simplify your extra diffusion term as:
grad.(De*gradS) - where De is some effective coefficient, then in the above domain contributions (either reaction or species source), you can just type:
d(De*d(S,x),x)+d(De*d(S,y),y)
Alternatively, you can also use weak form (domain contribution), if you want to, for which you can refer to the user manual.
So effectively, you are augmenting equation based modelling with the existing module to minimize your work.
The above is in 2D, so you can extend it to 3D.  But be careful with 2D axisymmetric because you will need to add additional terms, which I did not discuss.
I am sorry, if this turns out to be wrong.
Suresh
grad.(De\*gradS) - where De is some effective coefficient, then in the above domain contributions (either reaction or species source), you can just type:
d(De\*d(S,x),x)+d(De\*d(S,y),y)
Suresh
                                7 years ago
                                Feb 19, 2019, 4:17 a.m. EST
                                                    Hi Suresh
Thanks a bunch for your reply. Your solution makes sense and i also think i should work. I'll try it out and report back.
Cheers
Trygvi
                            Hi Suresh
Cheers
Trygvi
