Solid with trapezoidal section
I am trying to create a solid block with a trapezoidal cross section.
I tried creating a trapezoid using the polygon option and then converting that to a surface and finally, extruding the surface to form the block.
However, I get an error when I try to convert the polygon to surface. It says at least two vertices are required.
Can anyone suggest alternate methods to create the block?
1 Reply Last Post Apr 19, 2012, 7:17 p.m. EDT
Posted: 1 decade ago Apr 19, 2012, 7:17 p.m. EDT
1. Create workplane
2. Create polygon within the plane. Choose Type:Solid
3. Extrude the plane
1. Create workplane 2. Create polygon within the plane. Choose Type:Solid 3. Extrude the plane
