Reset dependent variable to initial values during execution
Posted May 8, 2012, 4:09 p.m. EDT Low-Frequency Electromagnetics Version 3.5a 8 Replies
Attached is a bidomain model representing heart tissue that we are developing. After every 6s of execution I need to reset the dependent variables to their initial values. Is that possible in COMSOL? If so how?
Specifically in the attached model, I need to reset the value of Vm, a dependent variable in the Bidomain model PDE to its initial value every 6s.
Deepika
I'd greatly appreciate if one of you can tell me if there is a means to reset dependent variable values forcibly in the middle of solving pdes.
Deepika
what do you mean by "reset initial conditions", you can do a sweep depending on a parameter or add a parametric sweep and restart your simulation from your initial conditions, including remeshing (see the doc), or you can have "oscilaltory BC's that goes back to given values at a given time (needs often to tweak somewhat the solver settings but it works mostly nicely) ...
Thanks for your reply...
Here's what I want to do:
After every 6s of execution of the bidomain PDE equations I need to set the value of Vm, a dependent variable to its initial value and continue execution. Here I need to set the value of Vm over a part of the domain as in the initial value expression:
if((x>0)*(y>0), Vfire, Vrest)
I sincerely appreciate your help.
Deepika
Deepika
I do not believe it's correct to act directly on the dependent variables, since these are the responses/solutions of your physics laws and the BC+initial conditions. You must act on the BC to get the solution to "reset" the dependent variables.
Or you start and stop your model, and redefine new initial conditions, also fully or partially using last solver time as new initial conditions.
The parameter sweep indeed changes parameters, but these parameters can drive BC values
I am trying to simulate a continuous phenomenon in cardiac electrophysiology where the heart tissue is reset to the same initial condition at the end of every ecg cycle...hence at the end of every cycle unless I reset the value of the dependent variable to that of the initial values the cycle will not repeat...It occurs once and then stops..
Is there any way to do this continuously without having to stop and start execution where I can preset the values of dependent variables at specific times and this override the values from the solver?
Deepika
I see only some cleverway with a parametric sweep, but something must change from restart to restart, otherwise you are just repeating N times the same simulation, or have I missed something ?
We want to be able to simulate N similar simulations imitating normal heart activity and then introduce a parameter that will trigger a different response simulating atrial fibrillation (AF). I was planning on using the parameter sweep to trigger AF but will have to figure out a way to simulate continuous cycles of normal heart rhythm first.
Suggested Content
- FORUM Initial Values setting during parametric sweep calculation
- BLOG How to Use Job Sequences to Save Data After Solving Your Model
- KNOWLEDGE BASE Manually Setting the Scaling of Variables
- KNOWLEDGE BASE My Flux Calculation Seems Wrong
- KNOWLEDGE BASE Segregated solver steps do not involve all components
