the domain of fluid
I am using the Conjugate Heat Transfer Model to model a structure with water cooling. I imported the solidworks drawing file to COMSOL. My question is what is the easiest way to define the domain of the fluid for the structure? The fluid region wasn't previously defined and the shape of the cooling pipe is very complicated.
Please help. Thanks a lot.
2 Replies Last Post May 22, 2012, 7:01 p.m. EDT
Posted: 1 decade ago May 19, 2012, 3:38 a.m. EDT
You hve in 4.2a a geometry caps option to close a pipe entry if it has a continuous and well behaved entry boundary, the same for the exit.
Try it out
Hi You hve in 4.2a a geometry caps option to close a pipe entry if it has a continuous and well behaved entry boundary, the same for the exit. Try it out -- Good luck Ivar
Posted: 1 decade ago May 22, 2012, 7:01 p.m. EDT
Thanks a lot!
Hi, Thanks a lot!
