Multiple steps/studies
Posted Feb 7, 2023, 3:52 p.m. EST General, Structural Mechanics, User Interface Version 6.1 0 Replies
Hello (word file would be better to read the quesiton)
I would like to see bolt force changes with regard to temperature and service load.
First, bolt is tightened.
Second, temperature is assigned.
Finally, service load is applied.
In order to run these simulations, I think I have two methods.
1) multiple studies
2) multiple steps.
(1) multiple studies
Study 1: Bolt pretension
Study 2: Heat transfer in solid-Thermal expansion
Study 3: Service load
Study 1 setting
1) Model configuration for study step
    Bolt pretension : Enable
    Heat transfer-thermal expansion : Disable
    Service load : Disable
2)Values of dependent variables
    Initial values of variables solved for : Physics controlled
    Values of variables not solved for : Physics controlled
Study 2 setting
    Heat transfer in solid-Thermal expansion : Enable
    Service load : Diable
    Initail values of variables solved for : User controlled/Solution/Study 1
    Values of variables not solved for : User controlled/Solution/Study 1
Study 3 setting
    Service load : Enable
    Initial values of variables solved for : User controlled/Solution/Study 2
    Values of variables not solved for : User controlled/Solution/Study 2
Multiple steps
Step 1
Step 2
    Heat transfer-thermal expansion : Enable
Step 3
    Question
    1) Are the settings for multiple studies and multiple steps proper?
    2) Would you please explain initial values of variables solved for/values of variables not solved for? using my simulation cases?
    3) For steps, I can use stored values for values of dependent variables. when should I use them? if I just select physics controlled for both solved for and not solved for, does it run the simulation as I intended? ( For example, heat transfer simulation will be done, based on the values calculated from bolt pretension)
Hello Y Ko
