Optimization Solver failure due to segregated step residual issue during heat transfer and topology optimization in evaporative cooling microchannel
Posted Jul 22, 2025, 12:41 a.m. EDT Fluid & Heat, Heat Transfer, Physics Interfaces Version 6.1 0 Replies
Hello, I am currently conducting a topology optimization study in COMSOL Multiphysics (v6.1) involving evaporative cooling using PDMS-based microchannels embedded in the backside of a solar panel. The goal is to optimize the internal cooling channel design using evaporative heat transfer effects in microchannels.
I have defined the following:
A volumetric heat source in the domain: Q=1,000,000W/m^3
A boundary heat source at pore boundaries: Q=-458336*(theta - 1)
Heat flux boundary condition on the outer surface: h = 5 W/m²·K, thickness 10 mm
Laminar flow is defined with:
Inlet pressure: Uin Outlet pressure: 0 Pa
Objective function for optimization: comp1.obj_T
Parameters and variables were entered as values for PDMS and water, and the heat-related parts were entered according to the sun's illumination.
But I keep getting this error - Feature: Optimization Solver 1 (sol1/o1) Failed to find a solution. Maximum number of segregated iterations reached. Returned solution is not converged. Not all parameter steps returned.
What should I do please help me
Hello Kim SeoJin
